matt1987 Posted September 10, 2006 Report Posted September 10, 2006 I don't know if this is in the reight section but, on my 95' GP, I have no clock display. It is a stock cd player. The cd player/radio everything works fine. Even the eq and preset buttons light up, but the clock/track number display doesn't light up. Is there a bulb inside the radio that illuminates that section, or am I screwed?? Thanks for any help Quote
ToroToro Posted September 10, 2006 Report Posted September 10, 2006 Should be in audio section. But the screen doesn't use a bulb. It sounds to me like one of the solder joints around the screen broke loose, and will need to be re-done. These radios aren't all that hard to get apart... Quote
Crazy K Posted September 10, 2006 Report Posted September 10, 2006 fixed this problem in a 91 Pontiac 6000. now... it may not be the smae probelm as yours suffers, but... I opened the radio to discover that a resistor looking part on the circuit board was visibly burned. there were two right next to each other and the must have been about 3/16" in diameter. I salvaged the exact same part from a junk radio I had and soldered it in place, and it fixed the issue. Quote
rockfangd Posted September 10, 2006 Report Posted September 10, 2006 your screwed its an all too common problem in gms, just like newer gms with the non stop hazard clicker .lol you fix it and it only breaks again. my pontiac sunfire 1995 i took a radio out of a 99 malibu and good as new. cd player and all, same plug and size Quote
Lord Bowler Posted September 10, 2006 Report Posted September 10, 2006 Yeah, I had to put in a new stereo in my 1997 Sunfird 'vert when the display went out. No big deal. Quote
fastbird232 Posted September 12, 2006 Report Posted September 12, 2006 You can easily fix it yourself. I have a link. EDIT: Here http://www.gaownersclub.com/forum/showthread.php?s=&threadid=40907 Quote
