Does my 89 Cutlass Supreme w/ 2.8 have an AIR PUMP? Or any type of AIR INJECTION SYSTEM such as an AIR DIVERTER VALVE?
I can hardly find any information on these topics in other Forums etc...
My OBD Scanner has a variable that shows something called an "Air Switch Solenoid" either "ON" or "OFF" and I never really decided to figure out what the hell it actually means, until now!
THANKS!:)
the AIR pump you referred to is only on motors equipped with a manual tranny
Robby
Hmmm...so I wonder why the hell my AutoXray Scanner has a variable for "Air Switch Solenoid"? Would this only be used on Manual trannies as well?
is it throwing codes? I found an "air select switching valve" in my wiring diagram of a 2.8. However, I cant find it any where in the book. Lemme know about the SES codes
Robby
It doesn't mean anything. If your car has an auto tranny, it doesn't have one. It's probably a valid parameter because there were manual versions of these cars.
