FordBoy Posted September 8, 2006 Report Share Posted September 8, 2006 Are w's known to rust from the inside out of the rear fenders?, having a idle missfire?, having brakelights work when they want to work(left and right only top is fine)?, wheelwell trim brake and fall off? And what is the correct size tires for my cutty i have 205/70R14's. But a friend has a '92 lumi it has 195/75R14 which is right? Quote Link to comment Share on other sites More sharing options...
fastbird232 Posted September 8, 2006 Report Share Posted September 8, 2006 It happens. Quote Link to comment Share on other sites More sharing options...
Brian P Posted September 8, 2006 Report Share Posted September 8, 2006 -in salty areas, sure -idle control motor, or other - bad turn signal switch - both sizes can be used, the 205/70/14 is the plus-size for 195/75/14, and more common. Quote Link to comment Share on other sites More sharing options...
Dark Ride Posted September 8, 2006 Report Share Posted September 8, 2006 It happens. A lot actually, at least to my car Quote Link to comment Share on other sites More sharing options...
Addicted2bass Posted September 8, 2006 Report Share Posted September 8, 2006 My Lumina started rotting around the rear wheelwells and the rocker panels. That happens to most cars around here that are older, the salt just eats them away. Its hard to stop it unless you dont drive in the winter. Quote Link to comment Share on other sites More sharing options...
