Trying to figure out where my oil leak is coming from (pics)
YOUR ALL WRONG!!!!
I have this similar problem.
It is the rear main seal.
Have fun pulling out the camshaft.
:smilielol:
Well, from the way it sounds, the FRONT main oil seal... They tend to leak after some miles... Parts stores sell a new seal and repair sleave for it since it typically happens because a groove gets worn on the crankshaft... And this comed from somoone who sells parts for a living :wink: I've sold several of them within the part year...
Just pull your wheel off and look if the harmonic balancer is coated with oil or not... That will give you a better idea
I have no clue what that is :lol:
K, I'll use a more simpler term, front crankshaft seal... Most autoparts stores sell a repair kit (dubbed harmonic balancer repair kit) or "QuikSleeve"
Brad, last chance. I'll give ya $1,744.20 for it !!!
That's it? lol
I would sell it to you, but I have to have a car for the time being...If I get a new car soon I'll sell it to you if I can, rather than trading it in.
Cuz I know you'll fix it up :wink:
WRONG!!!!!!!!!!!!!
Did I say rear main seal?
Nice try.
That would be obvious to see oil leaking from the front.
However that is a good start . . . .taking off the wheel.
:rolleyes:
I love INTRIGUES !!!! Did you know that the cars equipped with the Precision Control System have a higher first gear ratio it's 3.29 :1 with PCS 3.05:1 without it. I need to get a PCS car to see what she tops out at with the H rated tires and the Autobahn package.
did you fix the problem yet? mine leaks like that in the same location(for the most part) and i know its two different engines, but mine leaks from the drain plug..the drain plug washer is shot.
Well, my car no longer has H rated tires on it. :sad: Finally got some new ones
http://www.w-body.com/forum/index.php/topic,50160.0.html
