89Cutlass Posted September 3, 2006 Report Posted September 3, 2006 I have built a serial cable to attach to the aldl conector on my 89 cutlass 2.8 but i am unable to find software that works for my ECM. has anyone else done this with this motor/ecm. Which software works and supports this car. Thanks Everyone Quote
Psych0matt Posted September 3, 2006 Report Posted September 3, 2006 are you trying to tune it, or just to pull codes? if youre trying to pull codes, you just jumper two pins and the light will flash in a series to tell you what the codes are. if youre trying to tune it, then disreguard what I'm saying Quote
Supreme Cutlass Posted September 3, 2006 Report Posted September 3, 2006 I'd reccomend FreeScan, it works for most purposes (data monitoring, etc.) and it's free If you scroll down to "The Diagnostic Software" at http://www.aldlcable.com/ it has good reccomendations and screenshots. Quote
89Cutlass Posted September 3, 2006 Author Report Posted September 3, 2006 pulling the codes is simple, im trying to monitor the engine the the aldl ports with a specific cable i built. im looking for software like winaldl, efilive etc.. but software that works with my ecm Quote
Psych0matt Posted September 3, 2006 Report Posted September 3, 2006 ahh yes, check out the link above, should be at least a start to what you need Quote
Supreme Cutlass Posted September 3, 2006 Report Posted September 3, 2006 pulling the codes is simple, im trying to monitor the engine the the aldl ports with a specific cable i built. im looking for software like winaldl, efilive etc.. but software that works with my ecm the software you mentioned does work, you just need the obd-I version and you need to set it to your ecm/vehicle Quote
