(and no - burritos were not had for dinner!)
But seriously folks....
Bulk of the time, there's nothing. But on a sweeping r/h turn (not left) I'm hearing a tapping/clunking noise coming from the right rear area. It's rate of clunk is in direct correlation to speed. As soon as I pull straight again, it's gone. Don't have to be going very fast to hear it (20mph + I'm guessing).
Since I haven't pulled the back end apart before on this.... what can I expect? Is it a set of tapered rollers? I'm thinking I've got a bad bearing if so....
Ideas? Warnings? Suggestions?
Thanks.
You might also want to take a look and see if your Monoleaf pads are worn out.
I would think the wheel bearing is just starting to give up on ya
Yeah that's what I would say, but wheel bearings (at least rears) have never been a big deal on these cars IMO.
I would jack up the rear and take a look, chances are you'll see a bushing or something out of whack.
We're not talking a single 'thunk' though.
It's rythmical, and road speed dependant. Like as if you had a rock in your tread.
I flipped through the parts book anyhow - looks like it's a sealed hub unit back there anyhow.
So much for repacking/replacing a bearing. :(
If it gets worse I'll just grab one from the wreckers I guess.
