RedZMonte Posted May 14, 2003 Report Posted May 14, 2003 Here is my new boost guage setup. * 2 1/6" "Hiper" Reverse indiglo Boost guage * 2 1/6" Autometer Black Guage Cup * T in vaccume line to MAP sensor for Vaccume source I just screwed it directly to the plastic part of the steering column. It has a curve on the bracket so it bolted on the corner of the column and doesn't block any guages other then oil pressure. http://photos.yahoo.com/bc/redzmonte/lst?&.dir=/1990+Turbo+Grand+Prix&.src=ph&.begin=17&.view=t&.order=&.done=http%3a//photos.yahoo.com/bc/redzmonte/lst%3f%26.dir=/1990%2bTurbo%2bGrand%2bPrix%26.src=ph%26.view=t Shane Quote
1trucavalier Posted May 14, 2003 Report Posted May 14, 2003 nice! I finally got my new engine pics http://us.f1.yahoofs.com/users/4c3c795f/bc/Im000172.jpg?bcKglw.ApbdmGM2O http://us.f1.yahoofs.com/users/4c3c795f/bc/Im000173.jpg?bcKglw.AXEIfUnqQ Quote
RedZMonte Posted May 14, 2003 Author Report Posted May 14, 2003 http://photos.yahoo.com/bc/trucavalier/lst?&.dir=/&.src=ph&.begin=17&.view=t&.order=&.done=http%3a//photos.yahoo.com/bc/trucavalier/lst%3f%26.dir=/%26.src=ph%26.view=t here are some of them from your yahoo photo's. BTW I like your idea on mounting the BOV in place of the stock flex coupler. I am going to copycat your idea! Where did you tap your vaccume source? I taped my boost guage to the MAP sensor vaccume source. Is that where you BOV source is? Shane Quote
1trucavalier Posted May 16, 2003 Report Posted May 16, 2003 i tapped the map. you can also put a brass plumb fitting on the back of the upper manifold where the little square center screw is. I got one but i haven't installed it yet. I found out when I removed my cat that I do have a blown head gasket because I can smell coolant in the exhaust. So i have to tear down the damn motor and replace them Quote
