joey b Posted August 30, 2006 Report Posted August 30, 2006 I tried loosening the bolts holding the cogs in place and 3 turned relatively easily. The fourth, unfortunately, would not turn. Unfortunately this one that would not turn is the rear exhaust cam and I am unable to put an impact on there. I will probably have to replace my belt soon and this has me concerned. Any suggestions? I also don't know what I can fasten the cam to and not break it while I attempt to break the bolt loose. I also am concerned about snapping my wrench and having metal pieces go where I wish them not to. Any suggestions? Quote
jimmy91444 Posted August 30, 2006 Report Posted August 30, 2006 you can put a screwdriver in between the two rear cogs that will keep them frm turning. Quote
