Bake82 Posted August 29, 2006 Report Posted August 29, 2006 Hey guys, Anybody who knows the dolt sizes of the intermediate shaft bracket off a 282 tranny could you please let me know? A forum member is pulling one for me and would make it easier if we knew the sizes. Thanks!! Kyle Quote
turby Posted August 29, 2006 Report Posted August 29, 2006 Either a 10 mm or 13 mm socket. Or do you want the actual bolt size? Quote
Bake82 Posted August 30, 2006 Author Report Posted August 30, 2006 Either a 10 mm or 13 mm socket. Or do you want the actual bolt size? Sorry yes all I need was the socket size. Thanks turby! Quote
Guest TurboSedan Posted August 30, 2006 Report Posted August 30, 2006 mine is 13mm. i think it might be 15mm on the block side (that is if you are getting the bracket too). Quote
Bake82 Posted August 30, 2006 Author Report Posted August 30, 2006 mine is 13mm. i think it might be 15mm on the block side (that is if you are getting the bracket too). I need the bracket as the last piece to put a 5spd in my cutlass. So I need to pull the bracket and only the bracket. so 13mm and 15 mm you think?? Quote
intern8tion9l Posted August 30, 2006 Report Posted August 30, 2006 damn dude you were looking for that bracket like 6 months ago! Quote
Guest TurboSedan Posted August 30, 2006 Report Posted August 30, 2006 mine is 13mm. i think it might be 15mm on the block side (that is if you are getting the bracket too). I need the bracket as the last piece to put a 5spd in my cutlass. So I need to pull the bracket and only the bracket. so 13mm and 15 mm you think?? yeah. i'm gonna try to get some stuff done on my Cutlass today and will double check for you. Quote
brianteel Posted August 31, 2006 Report Posted August 31, 2006 the thread size is 10mm. the bolt head size is either 13 or 15 depending on what kind you buy. most of the bolts on the engine are m10 thread or m6 thread Quote
