Guest RedCutlassSL
Guest RedCutlassSL
I accidentally kissed a curb with my drivers side front tire last week at about 25 mph. Now sometimes i can hear a squeaking coming from it. It goes away when the brake is applied, but it is present at every speed, but not always. Any ideas? Don't ask how I hit the curb, it was more of a glancing blow.
Also, I am hearing noises sometimes from my rear struts? I'm sure they are shot, but I just want to confirm it.
Squal that disappears with applying the brakes is usually the pad wear indicators just starting to touch the rotor, hopefully that's just it...check the pads
My front rotors/pads are only about 8,000mi old and they started squeaking last Sunday after I dove through a huge puddle. Other then that they only squeak when there is alot of dust buit up.
Well.. is your lug nuts tightened properly?
Rotor got warped? Check it with a dial indicator.
Could be the wheels needs balancing after that minor curb accident?
