is my idle low? could be a problem
hey everyone i was drivin from my college to my house ( 2 1/2 hrs away) and y check engine light came on thats my first problem
mycar has been having a kinda rough idle every once in a while and it also idles at about 600rpms mabey 650 it has been before my check engine light came on
what do yall think could be a problem and mabey a fix
im takin my car to the college auto shop to see the code on sept8th but i have to drive home this weekend and i wanna see if i can do anything to help untill then
Get the code pulled, so we all know what it is, then well be able to go from there.
ok well then i have to wait till sept8th
god i wish i had a place to be able to do my own work up here at college
i want to do a tune up oil change and change the trans fluid but i dont have anywhere to do it and no lift
Go to autozone and theyll pull the code for you so you dont have to wait.
You dont need a lift. Just a jack, 1 or 2 jackstands and the tools.
does anywhere else do the codes for free b/c the closest autozone is 38 miles from me
pepboys or advance auto <= preferably advance b/c its about 5 min away
you can pull the codes your self on a 91.
got a paperclip?
read this it's in FAQ
http://www.w-body.com/forum/index.php/topic,31177.0.html
and then... you can look it up or ask one of us to tell you what it means.
remember it's like morse code. eash code flashes three time.
- - - is 12
- - - - - - - is 34
simple enough?
Yea, thats all well and good, but his car is a 95 ;) OBD1.5 FTW
Oops. I thought I read it was a 91. my bad.
I always assume that certain things need replacing. Oxygen sensor has been the reason for most of the check engine lights in my cars, you should repalce it if it is old anyhow.
basically I would start with a full tune up with new ac delco plugs, new air and fuel filter, oxygen sensor (inspect at least) an oilo change if it;s due are hasn't been done. see if it makes the car run bettter.
i wonder how much a full tune up will cost i know if i let the school d it its 7 bux labor but im thinkin parts ( im in college meaning i have no money
plugs about $2 each, and use ac delcos only unless you like being sorry.
oxygen sensor, bosch from autozone about $18
air filter (please don't get a fram!) purolater, $7 from advance auto
fuel filter deutch from autozone about $7
nickles and dimes. are you handy and do you have a few tools?
ill rpolly just buy the shit and let the auto dept do it for 7bucks lol
i dont have anywhere to even jack up the front tires
and are the fram airhog filters ok b/c they are like 1/3 the price of the k&n filter if im changing the filter i would liek to get a better filter
well i went to advance auto to see about my code and they said they would but they lent there scanner out and the person brok off pins
and then i asked where the other advance is and they told me the scanners at almost everystore are broken and advance dosent want to pay to get em fized
so yeah abck to waitin till sept8th
the car is runnin fine as long as taht stays im ok
w got the codes read on my car today as well as a full tune up
first off my car isnt idiling bad anymore and the power i had when i bought the car is now back
the code was code 342 cam sensor failure
we cleared the code but the light is still on so we went back in to see if there were any more codes and theres no more so now i have no codes but the check engine light is still on which is weird
let me know about the code and what i can do about the light now
