18incholdz Posted May 13, 2003 Report Posted May 13, 2003 I currently have 18 inch Mille Miglia Spiders w/ Yokohama Parada spec2's on my car...and i'm thinking of selling them and getting 20's....The 20's that found are 20x8.5...would that width fit on my car? And how much of difference is there between 5x115 bolt pattern, and 5x114.3 bolt pattern? Enough to not make them fit or no? Quote
18incholdz Posted May 13, 2003 Author Report Posted May 13, 2003 and another question....what does Offset mean? and what offset should i have? Quote
Slade901 Posted May 13, 2003 Report Posted May 13, 2003 Check this link http://www.usacomp.com/Offset.htm BTW, their second example of a positive offset shows 10.5 width wheel but their computation shows for a 11.5 width wheel but you will get an idea how they get the offset value by determining the width of the wheel - backspace = offset. Quote
GnatGoSplat Posted May 13, 2003 Report Posted May 13, 2003 20x8.5 will fit, and 5x115mm vs. 5x114.3mm is so little difference, it doesn't really matter. If you run an offset close to stock (+35mm to +42mm or so), I think the biggest tire you can run without rubbing is 245/30R20. 245/35R20 is much closer to stock diameter, but I think it will probably rub (there is already very little clearance for stock 225/60R16). Most of the time, the problem with aftermarket wheels is our caliper design means many aftermarket wheels won't fit even if the bolt pattern and offset are fine. I found that out the hard way, ugh. Quote
slick Posted May 13, 2003 Report Posted May 13, 2003 The difference between 115 and 114.3 is .7 millimeters. I can't even hold my fingers that far apart. In inches that is .027559, very little, not even enough to worry about. Quote
18incholdz Posted May 13, 2003 Author Report Posted May 13, 2003 Does anyone want to buy a set of 18 inch mille miglia spiders w/ yokohama parada spec 2's on them? they have been on my car for about 6 months...and probably close to 60% of tread left.... i'm askin 850 if anyone is interested...i paid close to 1500 for them Quote
mdelorie Posted May 13, 2003 Report Posted May 13, 2003 I probably would. But New York's a LOOOOONNNNGGG way from where I am. Quote
18incholdz Posted May 13, 2003 Author Report Posted May 13, 2003 i have pictures...but no scanner to put them on the computer Quote
18incholdz Posted May 13, 2003 Author Report Posted May 13, 2003 there is pictures of the rims on tirerack.com Quote
mdelorie Posted May 13, 2003 Report Posted May 13, 2003 Hmmm, well... 850 works out to about 1200 CDN right now. (good thing our dollar's doing well) Probably cost an arm and a leg for shipping / customs, etc. What size is the the rubber? Quote
