Crazy K Posted August 29, 2006 Report Posted August 29, 2006 damnit! I'm finding my measuring tape! will post results soon. Quote
1990lumina Posted August 29, 2006 Report Posted August 29, 2006 you seem like the type of person that gets things done lol...i'll fly you up to Saskatoon, give you PIN and debt card...you can go buy all parts needs to rebuild my Lumina 100% haha... Quote
Guest TurboSedan Posted August 29, 2006 Report Posted August 29, 2006 i thought the larger booster was only on '96/'97 cars? Quote
Crazy K Posted August 30, 2006 Report Posted August 30, 2006 any car with the 3100 that i have seen (have not seen a 93 Cs w 3100) had a larger booster than the 3.1 I believe the 3.1 booster is a smaller diameter, but is longer and thereby should have about the same volume as the 3100 booster YES it can fit, if you modify some stuff under the hood. the 3.1 has alot of wires and hoses that run up and over the booster, these will have to be forced out of the way a bit, but the biggest obstruction is the metal line that feeds to the heater core. it would have to be cut down with a new hose to route it further to the right side of the car, but it could be done, if someone whats to try and then post the results!!!!!!!!!!!!!!!!!!! Quote
