wreckless123 Posted August 24, 2006 Report Posted August 24, 2006 I just picked up a 91 Buick Regal for cheap with low miles. This thing runs and drives great the only problem is the brakes. The previous owner has over $4000 in reciepts for brake work over the past three years from pads, rotors, drums, flex hoses ect. He even at one point had the ABS unit go bad and had it rebuilt. When I got it the brake pedal suprised me because as you came onto the pedal with any amount of preasure it would kick back for the first second, almost feeling rigid! Then it would brake decent. On my drive home both the ABS light and Brake light was on. I checked the fluid level and it was waaaayyyyy low. I filled it and took it for a drive. Looks like the Brake light went off but the ABS light is still on and the pedal still kicks! Any ideas? Thanks... Quote
97loudcut Posted August 24, 2006 Report Posted August 24, 2006 Another faulty ABS unit? Try pulling out the fuse for the ABS (this would shut off the ABS) and take it for a drive and see how the brakes react. I pull my ABS fuse on all my vehicles because ABS is what caused me to crash my first car (97 Cadillac STS) Quote
Crazy K Posted August 24, 2006 Report Posted August 24, 2006 OH GOD. He has a powermaster! best info on the PMIII rape you in the ass and take your money machine is here: http://tpsgarage.com/TGP/brakes/powermaster.htm http://tpsgarage.com/TGP/brakes/Braking_main.htm http://tpsgarage.com Quote
White93z34 Posted August 24, 2006 Report Posted August 24, 2006 give it a rest ken, theres plenty of people here that can make maintaining a PMIII system affordable. Quote
LukeZ34 Posted August 24, 2006 Report Posted August 24, 2006 The Powermaster in the TGP was doing this same thing. Bleeding the brakes at all 4 calipers, and at the master cylinder fixed the problem. Quote
wreckless123 Posted August 24, 2006 Author Report Posted August 24, 2006 I will pull the ABS fuse tonight and see if it helps.. If not I will try to bleed the brakes.. How do you bleed the mastercylinder when it is on the car? I have bench blead them before but unsure how to do it on the car? Quote
LukeZ34 Posted August 24, 2006 Report Posted August 24, 2006 Follow this procedure for bleeding: http://tpsgarage.com/TGP/brakes/powermaster.htm#BLEEDING Save yourself the time, DON'T pull the ABS fuse. It will NOT fix your problem. You have an electrical braking system, and pulling ANY fuse will render it completely inoperable. Quote
wreckless123 Posted August 25, 2006 Author Report Posted August 25, 2006 Well I bled the brakes in the proper sequence and it dident help. What surprised me is when I pulled the cover off the master cylinder the rear fluid was white with bubbles I think?!?! Is that normal? It eventually cleared up.. Anymore ideas its still kicking me.. Quote
Crazy K Posted August 25, 2006 Report Posted August 25, 2006 give it a rest ken, theres plenty of people here that can make maintaining a PMIII system affordable. geez being sardonic doesn't carry well on the forum does it? But hey i did post the links to help out our new member. hope that helps! Quote
mfewtrail Posted August 25, 2006 Report Posted August 25, 2006 The powermaster system will have some "pedal feedback"(kick back as you're describing it) to it, that's normal. How many pedal presses do you get before your hear the abs motor running? Also, with the fluid low, you could have a leak somewhere(rear of the ABS housing or the proporitioning valve at the rear of the car could be leaking). If you can find no leaks, then maybe you got lucky and the previous owner or whoever else worked on the car simply didn't fill up the master cylinder to the proper level. Quote
wreckless123 Posted August 26, 2006 Author Report Posted August 26, 2006 The powermaster system will have some "pedal feedback"(kick back as you're describing it) to it, that's normal. How many pedal presses do you get before your hear the abs motor running? Also, with the fluid low, you could have a leak somewhere(rear of the ABS housing or the proporitioning valve at the rear of the car could be leaking). If you can find no leaks, then maybe you got lucky and the previous owner or whoever else worked on the car simply didn't fill up the master cylinder to the proper level. Not this much, its frightening how much kick back I get for the first second. It feels like the pedal is solid as a rock, then it go to feeling normal.. Quote
rockfangd Posted August 27, 2006 Report Posted August 27, 2006 yeah screw abs i totalled my first car thanks to abs. i would rather just use the feature to lower my insurance. lol Quote
Supreme Cutlass Posted August 27, 2006 Report Posted August 27, 2006 yeah screw abs i totalled my first car thanks to abs. i would rather just use the feature to lower my insurance. lol The powermaster III is different than most ABS systems though... it's not like you can just say screw it and pull the fuse and excpect it to work properly. Quote
Bossman429 Posted August 31, 2006 Report Posted August 31, 2006 My TSTE did that when I bought it, it also had brake fluid seeping out of the cap. In my case it was because someone filled the reservoir without properly bleeding the master cylinder (40 pumps) prior to removing the cap. If you don't bleed the system the level won't be correct when topping it off. Quote
