blkinternational Posted August 23, 2006 Report Share Posted August 23, 2006 befor i get yelled at for not searching... I DID SEARCH all i got find was Topic: How to replace your signal switch and i read about it and my cars not having that problem.. my turn signals just wont work all the other lights work i cant figure it out! Quote Link to comment Share on other sites More sharing options...
blkinternational Posted August 23, 2006 Author Report Share Posted August 23, 2006 just nothing happens when i turn them on no indicator or no flash outside Quote Link to comment Share on other sites More sharing options...
blkinternational Posted August 24, 2006 Author Report Share Posted August 24, 2006 yes brake lights work when i bring it back twords me still nothing Quote Link to comment Share on other sites More sharing options...
Euro Posted August 24, 2006 Report Share Posted August 24, 2006 Try bringing the stalk back towards you with the signal on. If they come on, switch time. dammit...thats me. I was hoping it was just a flasher fuse. i wonder if i can stand it for another X amount of months til i get another car Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted August 24, 2006 Report Share Posted August 24, 2006 yes brake lights work when i bring it back twords me still nothing Okay, how do I interpret this statement? 1.) Yes, brake lights work. When I bring it back towards me, still no signals. or 2.) Yes, brake lights only work when I pull the lever back towards me. Still no signals, though. Answer to both would be to change your flasher. It's located near the base of the steering column near where it passes through the firewall. If #2 is what you were trying to say, then both your flasher is shot (for the "no signals") and your signal switch is shot (for the "no brake lights until pulling on the signal lever.") In either case, I see you have a 94, and I have just what you need: http://tss.likeabigdog.com Quote Link to comment Share on other sites More sharing options...
blkinternational Posted August 24, 2006 Author Report Share Posted August 24, 2006 ok my brake lights work fine no matter what just the blinkers arnt working at all like nothing Quote Link to comment Share on other sites More sharing options...
97loudcut Posted August 24, 2006 Report Share Posted August 24, 2006 Blinker Fluid (Sorry I had too) Quote Link to comment Share on other sites More sharing options...
blkinternational Posted August 24, 2006 Author Report Share Posted August 24, 2006 i already check that it was a lil low so i topped it off Quote Link to comment Share on other sites More sharing options...
IRONDOG442 Posted August 24, 2006 Report Share Posted August 24, 2006 It sounds like you will be learning how to do a multifunction switch Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted August 24, 2006 Report Share Posted August 24, 2006 Flasher, fo shizzle. CLICKIE! Quote Link to comment Share on other sites More sharing options...
blkinternational Posted August 24, 2006 Author Report Share Posted August 24, 2006 went to murrays got the flasher (8 dollers) put it in... WORKS GREAT! thanks for the help guys! Quote Link to comment Share on other sites More sharing options...
LumiDriver Posted August 25, 2006 Report Share Posted August 25, 2006 At least it isn't the TSS. I have that issue with my car....glad you got yours fixed tho, and it wasn't the turn signal switch. Quote Link to comment Share on other sites More sharing options...
UWISHU1 Posted February 26, 2007 Report Share Posted February 26, 2007 would it be the flasher even if the Hazard lights worked?? Quote Link to comment Share on other sites More sharing options...
jeremy Posted February 26, 2007 Report Share Posted February 26, 2007 would it be the flasher even if the Hazard lights worked?? yes, IIRC there are two seperate flashers....one for the turns and the other for the hazards Quote Link to comment Share on other sites More sharing options...
rockfangd Posted February 26, 2007 Report Share Posted February 26, 2007 Blinker Fluid lolol could be (Sorry I had too) Quote Link to comment Share on other sites More sharing options...
