RebelGT Posted May 12, 2003 Report Posted May 12, 2003 can someone measure the width of their non turbo radiator for me, that would be great. Quote
RebelGT Posted May 13, 2003 Author Report Posted May 13, 2003 can someone walk out to their car with a ruler please? Quote
Slade901 Posted May 13, 2003 Report Posted May 13, 2003 These are the available radiator and specs for my 1990 Oldsmobile Cutlass Supreme SL 3.1L V6 Make: GM Comments: w/o Heavy Duty Cooling Core Size: 28 1/4'' x 15'' x 1 1/8'' (1 Row) Inlet Header Size: 2 1/4'' x 16 1/2'' Outlet Header Size: 2 1/4'' x 16 1/2'' Inlet Connector Size: 1 5/16'' Left Outlet Connector Size: 1 5/16'' Right Type of Mount: Saddle Mount Oil Cooler: 11 1/2'' (4 Plate) Comments: Plastic tanks/aluminum core. Sensor fitting on R.H. tank. OR Make: GM Comments: with Heavy Duty Cooling Core Size: 28 1/4'' x 15'' x 1 3/8'' (1 Row) Inlet Header Size: 2 1/4'' x 16 1/2'' Outlet Header Size: 2 1/4'' x 16 1/2'' Inlet Connector Size: 1 5/16'' Left Outlet Connector Size: 1 5/16'' Right Type of Mount: Saddle Mount Oil Cooler: 11 1/2'' (4 Plate) Comments: Plastic tanks/aluminum core. Sensor fitting on R.H. tank. Quote
ron350 Posted May 14, 2003 Report Posted May 14, 2003 RebelGT what car do you have, are you having cooling problems. Quote
NDN-Grand Prix Posted June 19, 2003 Report Posted June 19, 2003 Has anyone taken apart thier radiator?, if you have was it easy or hard, or can it be done. i was looking at mine and it looks like there's the side clips that need to be bent straight. If anyone knows please post it. 95 Grand Prix 3100. Quote
mfewtrail Posted June 20, 2003 Report Posted June 20, 2003 Has anyone taken apart thier radiator?, if you have was it easy or hard, or can it be done.i was looking at mine and it looks like there's the side clips that need to be bent straight. If anyone knows please post it. 95 Grand Prix 3100. Why would you need to take your radiator apart? got a busted plastic end-tank? 8) I've got a "good" radiator here with a busted endtank that I'm looking into getting fixed for an extra. Quote
slick Posted June 20, 2003 Report Posted June 20, 2003 Mine measured at approx. at 35 inches long. I hope that was what you were wanting. Quote
JS91Z34 Posted June 20, 2003 Report Posted June 20, 2003 RebelGT what car do you have, are you having cooling problems. Had cooling problems, but I fixed it though! Quote
