does anyone know how much fluid a 94 olds cutty supreme 3100 holds for tranny fluid. i recently did a tranny flush and fill but i have added 5 quarts and it is still way too low. any ideas
[attachment deleted by admin] Removed to free up storage space.
did you just drop the pan, or pump out all the old fluid? If you just dropped the pan, it will take a little bit more than 6 liters. If you pumped out all the old stuff, than its around 10 liters.
When I dropped my pan, replaced filter and that, it took like 10 quarts if I remember right. I couldnt beleive how much fluiid was in there.
dropped the pan and changed the filter. how many qts
Read my above post..
thanks everyone well i put in 5 quarts and i see no leaks nor did it leak before
