blkinternational Posted August 21, 2006 Report Posted August 21, 2006 when i riped apart my engine to fix the blown headgasket i disconected a wire. well atleast i thought i disconected it, it looks as if i broke it? and my tempiture gauge isnt working so im guessing this is why. the wire end is a square and it looks like its broken off and it wont connect back into the sensor. went to autozone/murrays the new one already has the wire attachted. i cant figure out how i would put a rachet on it and screw it back into the black when the wire is on it here is a link to said pics http://i46.photobucket.com/albums/f127/blkinternational/Picture514.jpg http://i46.photobucket.com/albums/f127/blkinternational/Picture515.jpg Quote
ToroToro Posted August 21, 2006 Report Posted August 21, 2006 You need to get a sensor socket with a slit down the side. You can get them in kits with all sorts of sizes. Quote
Crazy K Posted August 21, 2006 Report Posted August 21, 2006 I have always just used a wrench on them, and yes, I know the space is tight. Quote
Mach 5 Posted August 22, 2006 Report Posted August 22, 2006 That plugs in below the rear valve cover by the egr. I would rotate the engine and see if you can fit a socket on there. If not, maybe buy a universe rachet style wrench that will fit. -Did you have any trouble getting everything back together? I hope it all worked out well. Quote
blkinternational Posted August 22, 2006 Author Report Posted August 22, 2006 yeah i went and got a socket today.. i did have a little touble putting everything back togeather i ended up cracking the intake manifold when puttin a new pipe fitting in.. i had to go get a new one.. but besides that it wasnt that bad. but thanks for all your help with the pics n stuff Quote
blkinternational Posted August 22, 2006 Author Report Posted August 22, 2006 oh yeah toro toro do u still have your cutty? Quote
ToroToro Posted August 22, 2006 Report Posted August 22, 2006 Nope...not for a month or so. It's sitting here in the driveway with the heads off right now. Part of the reason haven't been on here is because I've been helping my kid with that, and this has been going on for a week now... The 3100 is being quite the snake on my plane. Quote
blkinternational Posted August 22, 2006 Author Report Posted August 22, 2006 wait why r the heads off what happend? Quote
ToroToro Posted August 22, 2006 Report Posted August 22, 2006 Bad head gaskets, filthy/bad injectors and an insanely loose rocker. Thing was banging like all hell. And this is a 109K mile motor. Quote
blkinternational Posted August 22, 2006 Author Report Posted August 22, 2006 shit tell me about the headgaskets i just replaced mine..what a job Quote
Mach 5 Posted August 22, 2006 Report Posted August 22, 2006 Its a job, but its all worth it in the end. So what brand of gaskets did you end up going with? Quote
rjtiminskygtp Posted August 22, 2006 Report Posted August 22, 2006 A buddy of mine just replaced his gaskets...it took him 2 weekends but he did it, and it was really worth it for the end result. Quote
Mach 5 Posted August 22, 2006 Report Posted August 22, 2006 It is definitely worth it. I just wish my injectors didn't fail on me after I had reassembled everything. A total of 13hrs of work can really take a toll on somebodys back. Quote
blkinternational Posted August 22, 2006 Author Report Posted August 22, 2006 i used felpro gaskets, and yes my back was killing me along with my head. hitting it on the hood mulitiple times really starts to piss me off...so thats why i removed the hood Quote
5speedz34 Posted August 22, 2006 Report Posted August 22, 2006 i used felpro gaskets, and yes my back was killing me along with my head. hitting it on the hood mulitiple times really starts to piss me off...so thats why i removed the hood How do you hit the hood!? Well, good to hear everything is back together. Yeah, that is the temp. sensor for the cluster. I broke one on my 3.4. Quote
Mach 5 Posted August 22, 2006 Report Posted August 22, 2006 Did you hit the hood latch? That thing was pissing me off. I didn't remove the hood though. Quote
blkinternational Posted August 22, 2006 Author Report Posted August 22, 2006 i dunno how the hell i hit the hood i hit it every time i stood up stright again mostly the corners... taking it off makes it so much easyer to do everything including spark plugs.. Quote
Mach 5 Posted August 22, 2006 Report Posted August 22, 2006 I probably should have done that. Didn't think of it. Quote
1990lumina Posted August 24, 2006 Report Posted August 24, 2006 I'd hate to take the hood off.....how do you get it perfectly aligned again??? Quote
blkinternational Posted August 25, 2006 Author Report Posted August 25, 2006 all i did was align it up with the marks the washer made Quote
Guest TurboSedan Posted August 25, 2006 Report Posted August 25, 2006 i always scribe around the hood hinges with a screwdriver before i pull it off, that way i can easily align it when i put it back on. Quote
