rockfangd Posted August 21, 2006 Report Posted August 21, 2006 hi everyone. i wanted to do a diagnostics on it but when i read the forum on the obd1 for earlier model w-body cars i have a 94 cutty 4 dr sedan 3100. the aldl under the dash only has 3 connectors unlike the forum, when i turn my ignition the serv eng light stays on until the car is started.. any help would be appreciated Quote
rockfangd Posted August 21, 2006 Author Report Posted August 21, 2006 so any way i can test it myself or can i just take it to like advanced auto or something Quote
94CutlassXtreme Posted August 21, 2006 Report Posted August 21, 2006 Probing the ALDL isnt going to make the engine light flash, and for the most part, no parts store has an OB2 scanner capable of pulling OBD 1.5 codes. You're most likely going to have to take it to a shop or the dealer. Basically 94-95 is an OBD 2 style ECM running OBD program. Some cars got the 12 pin ALDL and some have the newer 16 pin DLC. It's not prom like anything up to 93, and it's not flash like anything 96 and up. It's a bastard child of the two systems. And it's a pain in the ass to deal with. Quote
rockfangd Posted September 6, 2006 Author Report Posted September 6, 2006 why must everything be so difficult Quote
intern8tion9l Posted September 6, 2006 Report Posted September 6, 2006 obd 1.5 is the worst thing ever created Quote
Brian P Posted September 6, 2006 Report Posted September 6, 2006 I haven't seen a 16-pin diag connector on an "obd1.5" car. My '95 which was built in February '95 has the old style 12-pin...stock at least. An OBD1 scanner that reads data (not tries to flash the check engine light) will read "obd1.5" Quote
Crazy K Posted September 6, 2006 Report Posted September 6, 2006 thanks for the reminder, I thought about whether the obd 1.5 connector coulod be replaced (or even better, wired in parrallel) with a donor obd 2 connector and the system be read by the OBD2 computer. this is interesting, and I now have a laptop... http://www.aldlcable.com/ I would fab one up myself, if I can figure out how to do it, and read the info with one of those programs contained within. rockfangd, is your car having issues, or is the light just on? Quote
peeeot Posted September 7, 2006 Report Posted September 7, 2006 I used to have a '95 Camaro with the OBD "1.5" and it was not a thing to be happy about. I lucked out though: an Advance Auto Parts near me happened to have the Actron Super AutoScanner (CP9145), which is capable of reading both OBDI and II AND has the appropriate cables for both, among other things. I used it several times. Put the OBDII cable on and run an OBDI scan, and it pulls the codes with no problems. If you're lucky, a store nearby will have one. Most likely, however, your best bet is just to buy one of your own, off ebay or whatever. They aren't super cheap but if you plan on keeping the car a long time, it'd definitely be worth having. **All this assuming you have the OBDII style port w/16 pins but the emissions sticker says OBDI. It wasn't clear to me from the description whether that was the case. Quote
19Cutlass94 Posted September 7, 2006 Report Posted September 7, 2006 obd 1.5 is the worst thing ever created You aint kiddin there! OTC makes a scanner that you can use with OBD 1 ( or OBD1.5 for those who like to say that ) that works great! Although rather pricey, you can look at anything in the cars system. Quote
rockfangd Posted September 7, 2006 Author Report Posted September 7, 2006 well the light hasnt come on in the 2 years i have had the car so i wasnt sure if it was working properly. i ran a test by disconnecting the knock sensor and sure enough it did comeon lol Quote
