chadz34 Posted August 22, 2006 Author Report Posted August 22, 2006 Yeah, thats the IAC. So, in order to take the IAC out, I need to remove the throttle body? It's no biggie if that's the case, I'll have my dad help me. How do you guys clean it? Soak it in carb cleaner? Quote
slick Posted August 22, 2006 Report Posted August 22, 2006 Yeah, thats the IAC. So, in order to take the IAC out, I need to remove the throttle body? No, just take out the two torx bits as said by the 10 people in the above posts. Yeah, thats the IAC. How do you guys clean it? Soak it in carb cleaner? Carb cleaner will work, then get a pipe cleaner and wipe/scrub off any carbon build up. You will most likely have to reset the pintel height though. Quote
chadz34 Posted August 22, 2006 Author Report Posted August 22, 2006 Yeah, thats the IAC. So, in order to take the IAC out, I need to remove the throttle body? No, just take out the two torx bits as said by the 10 people in the above posts. Yeah, thats the IAC. How do you guys clean it? Soak it in carb cleaner? Carb cleaner will work, then get a pipe cleaner and wipe/scrub off any carbon build up. You will most likely have to reset the pintel height though. Alrighty, I'm gonna tackle that tomorrow. Thanks guys. Quote
5speedz34 Posted August 22, 2006 Report Posted August 22, 2006 Well if you're going to take the throttle body off you might as well clean all the carbon out of that too. Ohh and make sure to do a idle relearn because if you don't it will idle wierd until the pintle valve on the IAC adjusts itself. http://60degreev6.com/showthread.php?t=25012 Quote
fastbird232 Posted August 22, 2006 Report Posted August 22, 2006 Well if you're going to take the throttle body off you might as well clean all the carbon out of that too. He's not. It's not necessary. I cleaned the IAC on the GTP, and it didn't really change much (although I did it out of routine maintenance; it probably worked just fine). Quote
5speedz34 Posted August 23, 2006 Report Posted August 23, 2006 Well if you're going to take the throttle body off you might as well clean all the carbon out of that too. He's not. It's not necessary. I cleaned the IAC on the GTP, and it didn't really change much (although I did it out of routine maintenance; it probably worked just fine). Well, that's what I'm saying, it can't hurt can it? Also remember to get a TB gasket. Quote
fastbird232 Posted August 23, 2006 Report Posted August 23, 2006 Doesn't coolant run through that TB, though? Quote
GnatGoSplat Posted August 23, 2006 Report Posted August 23, 2006 Sounds like a lower intake manifold leak to me. Have the temperatures gone down where you are? Quote
5speedz34 Posted August 24, 2006 Report Posted August 24, 2006 Doesn't coolant run through that TB, though? It might, I don't think so though. Sounds like a lower intake manifold leak to me. Have the temperatures gone down where you are? LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. Quote
GnatGoSplat Posted August 24, 2006 Report Posted August 24, 2006 LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. It's my understanding GM didn't fix the LIM problem on their cars until sometime in late 2000. A bad LIM leak could definitely affect the engine when cold with ambient air temps in the 60's. Quote
chadz34 Posted August 25, 2006 Author Report Posted August 25, 2006 LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. It's my understanding GM didn't fix the LIM problem on their cars until sometime in late 2000. A bad LIM leak could definitely affect the engine when cold with ambient air temps in the 60's. Well the plan is, I am gonna get a new IAC, and if that doesn't fix it...I will have the LIM fixed becuase I already did the top intake gasket, but not the lower and I HAVE that gasket it came with the kit I got, so no need to buy parts. Quote
slick Posted August 25, 2006 Report Posted August 25, 2006 LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. It's my understanding GM didn't fix the LIM problem on their cars until sometime in late 2000. A bad LIM leak could definitely affect the engine when cold with ambient air temps in the 60's. Well the plan is, I am gonna get a new IAC, and if that doesn't fix it...I will have the LIM fixed becuase I already did the top intake gasket, but not the lower and I HAVE that gasket it came with the kit I got, so no need to buy parts. Why didn't you replace the bottom?? The top one hardly ever go's. That, and doing the whole job takes less than 2 hours. Quote
chadz34 Posted August 25, 2006 Author Report Posted August 25, 2006 LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. It's my understanding GM didn't fix the LIM problem on their cars until sometime in late 2000. A bad LIM leak could definitely affect the engine when cold with ambient air temps in the 60's. Well the plan is, I am gonna get a new IAC, and if that doesn't fix it...I will have the LIM fixed becuase I already did the top intake gasket, but not the lower and I HAVE that gasket it came with the kit I got, so no need to buy parts. Why didn't you replace the bottom?? The top one hardly ever go's. That, and doing the whole job takes less than 2 hours. Because it looks like coolant would go all over, I'd need a detailed description on how to do it. That, and I don't wanna fuck anything up by removing fuel lines and such. If there's a write up I would try it. Quote
slick Posted August 25, 2006 Report Posted August 25, 2006 LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. It's my understanding GM didn't fix the LIM problem on their cars until sometime in late 2000. A bad LIM leak could definitely affect the engine when cold with ambient air temps in the 60's. Well the plan is, I am gonna get a new IAC, and if that doesn't fix it...I will have the LIM fixed becuase I already did the top intake gasket, but not the lower and I HAVE that gasket it came with the kit I got, so no need to buy parts. Why didn't you replace the bottom?? The top one hardly ever go's. That, and doing the whole job takes less than 2 hours. Because it looks like coolant would go all over, I'd need a detailed description on how to do it. That, and I don't wanna fuck anything up by removing fuel lines and such. If there's a write up I would try it. Basically, before you disconnect the battery, pull the fuse for the fuel pump and start the car. That way, any gas in the lines will be used up, and you will have minimal leakage. Then, follow the steps to remove the upper plenum. Remove the bolts the hold down the fuel rail. You will then have to pop the injectors out of the LIM. Basically, just pull up on each individually. There should be enough play in the lines to kina swing it to the side(I was able to on my 93 Z34 with 95 3.4, not sure what the 96-97 style is like). This would be a great time to soak them in some carb cleaner while you do the rest. Just be sure to get them dry once you pull them out. Basically, follow this for the rest of it: http://60degreev6.com/showthread.php?t=24977 Quote
dohcfiend Posted August 25, 2006 Report Posted August 25, 2006 LIM, I don't think where a problem on the 96-97 3.4's since they use a different gasket completely. And the temperatures haven't gone down to much here. It's about the same where Chad is at. 60's-80's. It's my understanding GM didn't fix the LIM problem on their cars until sometime in late 2000. A bad LIM leak could definitely affect the engine when cold with ambient air temps in the 60's. Well the plan is, I am gonna get a new IAC, and if that doesn't fix it...I will have the LIM fixed becuase I already did the top intake gasket, but not the lower and I HAVE that gasket it came with the kit I got, so no need to buy parts. Why didn't you replace the bottom?? The top one hardly ever go's. That, and doing the whole job takes less than 2 hours. Because it looks like coolant would go all over, I'd need a detailed description on how to do it. That, and I don't wanna fuck anything up by removing fuel lines and such. If there's a write up I would try it. u need a write-up to pull an intake???? ever considered taking it to a shop?? sometimes DIY in the wrong hands can cost more money than getting a professional to do it. i would suggest buying a chilton's manual and if u really want to DIY go practice on a few cars in the boneyard to get some experience. Quote
