Mach 5 Posted August 21, 2006 Report Posted August 21, 2006 Ive got a problem. Which size tire for my car? The car is a 1989 Pontiac Grand Prix SE. The tires on there now are Yokohama Avid 215/60/R16 94H. On http://www.tirerack.com I get the size 225/55/R16. So which is the right one. I wouldn't mind the 60 but if the car originally came with 55's, then the speedometer would be off or not within spec. Also is 215mm or 225mm the correct width of the tire? Thanks Quote
Schudini Posted August 21, 2006 Report Posted August 21, 2006 What wheels are on your car? A pic of the stock wheels should help determine the stock tire. I have the stock 8" wide crosslaces on my 92, and I run 225/60-R16 (the stock size). Quote
1990lumina Posted August 21, 2006 Report Posted August 21, 2006 there is a sticker on the trunk lid?? or driver's door that will say correct (stock) tire size... if u use one of those tire size calculators based on the correct (stock) size, you will be able to find other tire sizes that will equal to the same circumference so your speedo won't be out, and it won't be dangerous to drive... Quote
89GP_SE Posted August 21, 2006 Report Posted August 21, 2006 I just sold my 89 GP SE so I will tell you, look in the trunk and on the trunk lid on the left it is right there. I will also tell you that the correct tire size for that car is 215/60R/16. If you put 225/60R/16's on it, the speedo will be out by 5 miles an hour. Quote
Mach 5 Posted August 21, 2006 Author Report Posted August 21, 2006 I have the white alloy wheels. Will the 225's fit on my car? Quote
89GP_SE Posted August 21, 2006 Report Posted August 21, 2006 the 225's will fit fine, but will put out the speedo a bit. I found that 225's give a better ride dunno how that worked out Quote
Brian P Posted August 21, 2006 Report Posted August 21, 2006 I had 225/55R16 on my Cutty and it was a nice fit. It's has just the slightest bit shorter sidewall than the 215/60/16. 225/60 is "ok" but the sidewall is a bit tall for my taste. Quote
THe_DeTAiL3R Posted August 21, 2006 Report Posted August 21, 2006 I've never seen or heard of (stock) tire size with "55" in it... ? Quote
Mach 5 Posted August 21, 2006 Author Report Posted August 21, 2006 I just checked the label in the trunk and it says 215/60/R16. So I guess that what Im going to buy. I never there was a label there. Thanks Quote
1990lumina Posted August 22, 2006 Report Posted August 22, 2006 I've never seen or heard of (stock) tire size with "55" in it... ? I think my mom's CL as "55" in it..i'll double check tomorrow Quote
mfewtrail Posted August 22, 2006 Report Posted August 22, 2006 I've never seen or heard of (stock) tire size with "55" in it... ? I think my mom's CL as "55" in it..i'll double check tomorrow Pretty sure Dave was referring to W-bodies only... Quote
mfewtrail Posted August 22, 2006 Report Posted August 22, 2006 Didn't TGPs have 245/55/16s stock? Or 245/50/16? 245/50's Quote
5speedz34 Posted August 22, 2006 Report Posted August 22, 2006 I've never seen or heard of (stock) tire size with "55" in it... ? I want to say 92-98? GA's got 55 series sidewalls. Quote
Brian P Posted August 22, 2006 Report Posted August 22, 2006 Newer Grand Am's usually have 225/50R16 on the GT's. 225/55/16 is stock on many V6 Camaro's and Mustangs. It's not the most abundant size, but I like it. 225/55 usually has a slightly wider tread width than 225/60 even though it's the same measured width. Quote
