19Cutlass94 Posted August 20, 2006 Report Share Posted August 20, 2006 Ok, I found something thats loose, but I have a couple questions before I try to tighten it up. First off, the nut by the lower spring seat is not as tight as it should be. Is it OK to just put a cresent wrench on it and go to town? Because I dont know what 'special' tool might be needed, and I have to get inbetween the coils of the spring. The car is sitting in the garage. But is it ok to tighten that with the load of the car on it? Or does that corner need to have no weight on it? Im just asking because Ive never done this before. TIA Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted August 21, 2006 Report Share Posted August 21, 2006 the nut by the lower spring seat? Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted August 21, 2006 Author Report Share Posted August 21, 2006 yes. The GM service manual says it should be turqued to 85 ft-lbs. I dont know what its torqued to now, but I know its loose because its moving. I can photocpoy the page out of the book if needed. Quote Link to comment Share on other sites More sharing options...
Pabz Posted August 21, 2006 Report Share Posted August 21, 2006 Are you talking about the "nut" that requires the strut cartridge removal tool? Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted August 21, 2006 Author Report Share Posted August 21, 2006 I dont know if it requires a tool or not. Its not on top, by the bearing plate/upper spring mount. Its by the lower spring mount. Its a thin sliver nut. If you lift up the dust boot inside the spring, youll see it. Quote Link to comment Share on other sites More sharing options...
Pabz Posted August 21, 2006 Report Share Posted August 21, 2006 Ya thats the strut cartridge nut, you'll need a tool like http://buy1.snapon.com/catalog/item.asp?item_ID=12168&group_ID=1635 Here is the guy using it http://www.shoptoolsshoptools.com/shopexd.asp?id=191 make sure the wheels stay on the ground! Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted August 21, 2006 Author Report Share Posted August 21, 2006 The car is sitting the garage, its not coming off the ground Well I guess its off to autozone to see if I can rent one, or off to the garage to see if I can tighten it without the tool. Quote Link to comment Share on other sites More sharing options...
