rakooon Posted August 19, 2006 Report Share Posted August 19, 2006 ok im almost done with the upgrade to the Electronic climate control, i have all the wires hooked up besides the inside temp sensor and the fan speed contrller. where do the thick red and black wires go to from the fsc? i cant seem to get any airto come out because of it and the fan motor will not engage. help please!! and thanks again baker Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 20, 2006 Author Report Share Posted August 20, 2006 Bump Quote Link to comment Share on other sites More sharing options...
Crazy K Posted August 20, 2006 Report Share Posted August 20, 2006 we aren't quite clear on what you are saying. clarification? have you read this? http://www.wbodysource.com/modules.php?op=modload&name=News&file=article&sid=20&mode=thread&order=0&thold=0 Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 20, 2006 Author Report Share Posted August 20, 2006 Thats it thanks alot!!! the only other install write up was brian p's......Thanks again Jared Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 21, 2006 Author Report Share Posted August 21, 2006 Ok ran into another problem... I need a visual or just a good explanation of where the temp motor door is located, to get to the harness.... then im done so if you have a pic or can bassicly walk me through it to find it.. thanx Quote Link to comment Share on other sites More sharing options...
Crazy K Posted August 21, 2006 Report Share Posted August 21, 2006 temp motor? it is mounted directly on the right side towards the front of the hvac case. I have no pic of it... lets see... obviuosly black, and about the size of a deck of cards. on corner is rounded... and I am sure you could see it on the far left side through the hole that the dash guts sit in. Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 21, 2006 Author Report Share Posted August 21, 2006 SEE IT? the pics are side ways Quote Link to comment Share on other sites More sharing options...
Crazy K Posted August 21, 2006 Report Share Posted August 21, 2006 thats ok, my head was sideways when I looked at it! towards the bottom of the pic, there's the item mounted of the vertical face of the hvac box. I can see the two wires coming off of it and heading to the right. right behind and slightly below the vacuum powered motor/selonoid Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 21, 2006 Author Report Share Posted August 21, 2006 i made a red box around what i think it is... is that it? Quote Link to comment Share on other sites More sharing options...
Crazy K Posted August 21, 2006 Report Share Posted August 21, 2006 yes Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 21, 2006 Author Report Share Posted August 21, 2006 ok but on the write up it say to use the brown wire in that harness i dont see a brown wire... so ill mess with and see what works.. thanks for all the help Quote Link to comment Share on other sites More sharing options...
rakooon Posted August 21, 2006 Author Report Share Posted August 21, 2006 im back....now i have it hooked up but i cant get the air to blow out on any other speed but high... i put it on low and it still blows out on high... what did i do wrong Quote Link to comment Share on other sites More sharing options...
