jimmy91444 Posted August 18, 2006 Report Posted August 18, 2006 I need an engine for my 94 supreme 4 d, this one knock. Witch one should I replace it with so I don't have to worry about piston slap or broken cam? Any sugestion? it's a 3100 Quote
jimmy91444 Posted August 18, 2006 Author Report Posted August 18, 2006 No thank's I got one of those. I probaly did not explained myself properly .What I meant is: what other year the 3100 was better than 94-95? Or were they all the same ( about piston slap and hollow cam)?/ Quote
firefighter_0029 Posted August 18, 2006 Report Posted August 18, 2006 Put a regular 3.1 in it. I have one with an ECM if you want it. Quote
jimmy91444 Posted August 18, 2006 Author Report Posted August 18, 2006 i was thinking about that also.Put a 3.1 bottom end,with a 3100 top end. I am in Canada, that would be quite a shipping charge.thank's anyway. Quote
Crazy K Posted August 19, 2006 Report Posted August 19, 2006 Who needs an engine? delete the engine and add a hampster wheel and load it with hampsters!!!! so say I have a problem with w 3100 and want to substitute a 3.1 as suggested... assuming you buy a 3.1 engine.... would it have to be a 94 3.1 Lumina ecm, or any 93 3.1 powered W would be fine? do you have to change the entire wiring harness? Quote
