IDLE ROUGH IN GEAR SMOOTH IN NEUTRAL
I have had my 89 cutlass89 2.8l for 5 years and always change my plugs wires oil air filter intake gaskets etc... but ive always had a weird idle
problem. Recently i changed the coil packs hoping it would help but it didnt.
The problem is my car will idle perfect in park/neutral and if i put it in gear it starts to miss and act like it wants to stall and will stall somtimes.
Im puzzled and cannot for the life of me figure out what the problem is.
other things ive changed
map sensor
02 sensor
cat converter
plugs/wires/3 coils
iac valve
intake gasket
throttle body gasket/cleaned throttle body
ANY SUGGESTIONS WOULD HELP A LOT.
THANKS
My lumina had this problem as well. It only happened while idling in gear during the summer. But it didn't occur when the a/c was on. basically the enige would idle lsightly below optimal idle and idle unevenly. even though it is set at the factory, upping it slightly may fix it.
injectors
clean the Throttle Body
Maybe that stupid dual exhaust design
my lumina does this too...well actually when the engine is running warmer then usual it does...i blame it on the coil packs getting heat soaked sitting down there by the exhaust manifold :rolleyes:
i wonder if it is the injectors. but its been the same for about 70k I would think the problem would have gotten worse.
There is also the odd time my car will stall and its hard to start again. but 99% of the time if fires up in 2 seconds. Then again in the mornings it stalls the first few times then its fine and runs ok.
I would check that throttle position sensor....Like Crazy K said, maybe up it a bit.
how old is the fuel filter. Ill get back to you with any ideas. I had a problem like this on my car a few years ago.
