mdelorie Posted August 14, 2006 Report Posted August 14, 2006 I've got my rear calipers off as part of my suspension project, and I'm wondering how to go about giving them a good cleaning. Obviously for the outside, brake cleaner will be fine, but what about the insides? obviously water is probably a bad idea, but is there anything you can spray inside the fitting where the braided line connects to clean the insides out? Quote
97loudcut Posted August 14, 2006 Report Posted August 14, 2006 if you want to clean them I would say clean the outsides up and put a coat of paint on them (black) it really cleans up the look of your wheels. Quote
Guest TurboSedan Posted August 14, 2006 Report Posted August 14, 2006 obviously water is probably a bad idea, but is there anything you can spray inside the fitting where the braided line connects to clean the insides out? i just sprayed a little Brakleen in there and then let it drain out. then make sure you bleed/flush your brakes good. i also sprayed/flushed the hoses with Brakleen while i had them out. Quote
