crc Posted May 9, 2003 Report Posted May 9, 2003 Has anyone replaced these by themselves? What tools do you need and what to watch out for. Thanks. Quote
red93z34 Posted May 9, 2003 Report Posted May 9, 2003 i've replaced ball joints on my 93 Z34, make sure you have a good impact gun with chisel tip. Quote
JS91Z34 Posted May 9, 2003 Report Posted May 9, 2003 now would be a good time to replace your control arm bushings if your replacing your ball joints! Quote
mdelorie Posted May 9, 2003 Report Posted May 9, 2003 I did my balljoints with nothing more than a socket set, a prybar and a blowtorch. It worked, but was a severe pain in the ass. Took about 4 and a half hours to do both. I'd recommend using either one of those balljoint separator tools, or the impact gun as previously mentioned. Aside from removing the ball joint from the control arm, it was a piece of cake. Something to watch out for: Once you remove the balljoint from the knuckle, make sure you don't move the axle / knuckle / strut assembly too far out or you run the risk of pulling it right out of the differential (so I'm told) Can anyone verify this? Quote
JS91Z34 Posted May 9, 2003 Report Posted May 9, 2003 the only thing people need to be careful with is the axle shaft. Pull on that thing too hard and you will end up repairing the inner joint or replacing the whole shaft. Quote
GnatGoSplat Posted May 9, 2003 Report Posted May 9, 2003 If you do accidentally pull the axle out of the differential (tranny), all you have to do is just push it back in till it clicks! Quote
Brian P Posted May 10, 2003 Report Posted May 10, 2003 I replaced them on my sister's '93, took maybe 1-2 hours per side. I drilled down the center of each rivet, till the hole just passed the surface of the joint, then used a chisel and with a hammer....1, 2, 3 the head falls off. Repeat 4 times, then pry the joint off with a prybar. As for the axle, I just removed the axle nut and used the puller to push the shaft partially out of the wheel bearing, just enough so it's "loose". Quote
crc Posted May 10, 2003 Author Report Posted May 10, 2003 Thanks gentlemen. The bushings I will diffenently replace along w/ the b-joints. The struts are only about a year old and the springs are fine. I'm wondering if there's anything else that effects ride quality because at this point I'm still feeling harshness on rougher surfaces, and harshness on all surfaces in low speeds. I would like to get back the tightness and better damping in the front suspension. Quote
Brian P Posted May 10, 2003 Report Posted May 10, 2003 What is the procedure to change out the control arm bushings? Is there an extractor tool? Quote
JS91Z34 Posted May 10, 2003 Report Posted May 10, 2003 There is a special procedure on changing CA bushings, but screw it. Alot of us don't have a press for the bushings, and the patience to use it. I did mine using a torch, 5# sledge hammer, and a socket the same size as the bushing sleeve(not the bushing itself) Take the two CA bolts out and remove the arm from the vehicle. Position the arm on a work bench, table, ground or whatever so you can strike it with a hammer. And for all of you reading this, don't worry you won't bend the arm if you hit it too hard! If you have access to a torch or something similar, use it. Torch the old rubber portion out of the control arm,(it will make lots of smoke and fire) and once that is out all you have to do is peel the sleeve out and put the new one in. It took me less than an hour to do both sides on my Z34. Quote
Brian P Posted May 11, 2003 Report Posted May 11, 2003 Do the bushing sleeves slip outwards or inwards?? Meaning, is there a locating lip on one end which prevents it from coming out in 1 particular direction? Quote
Brian P Posted May 11, 2003 Report Posted May 11, 2003 OK thanks for the tips.....now when I buy new bushings (expensive??) do they come with the sleeves? Quote
JS91Z34 Posted May 11, 2003 Report Posted May 11, 2003 No believe it or not the bushings are actually cheap. You can check with Energy Suspension for a list of their bushings. I'll see if I can dig up my receipt for my bushings. I went with a polyurethane bushing and spent a total of about 25 bucks for both sides. Yes they do come with the sleeves and are ready to install. One thing I should mention to anyone do CA bushings is that before you put them in, grease them up with a heavy weight grease before you install them in the arm and install the arm in the car. That will eliminate any possibility of an annoying squeak. Quote
Brian P Posted May 11, 2003 Report Posted May 11, 2003 I'm looking for rubber, I dont want to use poly in that particular part of the suspension. I'm going to do a quick check over the internet. I was going to get another set of control arms from my friend's parts car, but I THINK if I replace the CA's, I'll need an alignment. Plus new rubber is good! PS- you mean use grease on the sleeves to make it easier to install? Quote
JS91Z34 Posted May 11, 2003 Report Posted May 11, 2003 It would'nt hurt to have your alignment checked after replacing you CA bushings . I used poly's in mine, just because of the handling characteristics of them. the poly's dont compress and deform like rubber under load. Use grease on the sleeves and where the bushings contact the car. Quote
