I need to get the steering geometry checked on my Grand Prix, has anyone got the settings as no one in the UK can help me.
I can give you the geometry from when my car got an alignment, I hope itll help.
Both Left and Right FRONT Camber, Caster, Toe have the same specified range,
Camber - +0.2 to +1.2 degrees
Caster - +1.5 to +2.5 degrees
Toe - -0.10 to +0.10 degrees
Total for FRONT specified range
Cross Camber - -0.8 to +0.8 degrees
Cross Caster - -0.8 to +0.8 degrees
Total Toe - -0.20 to +0.20 degrees
Both Left and Right REAR Camber, Toe have the same specified range,
Camber - -0.4 to +0.6 degrees
Toe - -0.20 to +0.10 degrees
Total for REAR specified range,
Total Toe - -0.40 to +0.20 degrees
Thurst Angle - -0.15 to +0.15 degrees
Hope this helps!
