1988-5speedse Posted May 8, 2003 Report Posted May 8, 2003 can anyone explain how obd 1 works if so explain it to me it would help me out alot i know u can get a jump wire to a and b and put your key on the on postion and codes will flash trough the service engine light and all i get is 1 pause 2 if any one can help me i would appericate it thanks brandon Quote
Robby1870 Posted May 8, 2003 Report Posted May 8, 2003 code 12 or one flash, pause 2 flashes, means everything is okay, no codes Robby Quote
1988-5speedse Posted May 8, 2003 Author Report Posted May 8, 2003 well if it dose that code why in the fuck dose my car back fire all the time and dose not pick up any power and i have changed the coil packs the plugs plug wires and ignition control modual tell me how to make it stop back firing and i will kiss your ass Quote
Slade901 Posted May 8, 2003 Report Posted May 8, 2003 Yep possible blocked cat. Does the car IDLE rough and what happens if you rev the engine? Remove the O2 sensor out and start the car and compare the IDLE and rev it. If the engine is better without O2 sensor, you've got a blocked cat. Quote
1988-5speedse Posted May 9, 2003 Author Report Posted May 9, 2003 ok i figured it out today what was wrog with my car it is because i do not have a muffler on it and it dose not have the right back pressure so i am going to buy me a cheap muffler tomorrow Quote
Robby1870 Posted May 9, 2003 Report Posted May 9, 2003 He knew there wasnt a muffler just didnt figure it would casue a problem Robby Quote
Robby1870 Posted May 21, 2003 Report Posted May 21, 2003 Im guessin so. Anything without a muffler is going to be very loud. Robby Quote
