If one can get a custom aftermarket grind,will it be a full metal cam or will it be similar to the hollow tube design with the cam lobes pressed in or whatever GM did?
Are there any aftermarket cam grinds for the 3100 engine?If so whats a good grind and specs?Brand name as well?
Emissions arent a concern for this topic,just exploring ideas.
Thanks!
Basically the only person ( that I know of ) that can do custom grinds as well as stage 1, 2 is MMS. They will still be pressed on lobe. As far as whats a good grind for a cam, depends on what you want.
But heres a good read on what cams you can get.
http://60degreev6.com/showthread.php?p=223821#post223821
http://60degreev6.com/showthread.php?t=16566
Hey thanks for the info!Im gonna go read some more of it soon.
:cool:
