94 cs 3100 cam
Is the 94 3100 eng cam the same as the 95 3100?.The one that can break if coolant leak in the pan.
Well I've pulled the frt valves cover and everything is good. All the valves works.
No sparks so icm or cps.
Did the lower intake go on it or something? That's VERY common..
yes ,intake manifold gasket went ,it sat for about a month before i can get to it, and changed the oil, filter, and gasket. I just changed the icm and it run good except it now has a noise in it. Something is loose in there, may end up being a part car.
what kind of noise? Could you have forgotten to torque down a rocker arm?
No. It ran good for about 500 kms after changing the gasket, then the icm went and it started to fire unevently and then stop,had to be towed. Then i changed the icm and it started right away but had that noise. Sound like a piston slap,or something loose deep inside.But not so much at idle, it's louder when i rev it up.
