bubbles Posted July 27, 2006 Report Posted July 27, 2006 do they have the same fuel pressure regulator i was told they do but i dont think so.can someone help me Quote
mfewtrail Posted July 27, 2006 Report Posted July 27, 2006 The turbo and naturally aspirated 3.1's share the same regulator. AC Delco Part #217383 Quote
bubbles Posted July 27, 2006 Author Report Posted July 27, 2006 well some people talk about using RRFPR (Rising Rate Fuel Pressure Regulator) is this so they dont have to upgrade there fuel pump.or is for tuning issues Quote
mfewtrail Posted July 27, 2006 Report Posted July 27, 2006 well some people talk about using RRFPR (Rising Rate Fuel Pressure Regulator) is this so they dont have to upgrade there fuel pump.or is for tuning issues Well, it's not exactly used so you don't have to replace a fuel pump. The intended purpose of a rising rate regulator(commonly referred to as a "FMU") is to increase fuel delivery. If your stock fuel pump does not provide adequate flow for your horsepower level, than a FMU isn't going to do you much good. FMU's work well in certain cases, but there are other ways of increasing fuel delivery(such as tuning the stock computer to add more fuel via opening the injectors for longer periods of time). Search around on this board and you'll find that "TimG" used a FMU at one point on his custom turbo 3.4 DOHC setup as a method of "tuning"/adding more fuel. Quote
