18incholdz Posted May 6, 2003 Report Posted May 6, 2003 When i turn 18 in june i plan on taking out a personal loan to do my swap...I have a 1995 olds cutlass supreme w/ the 3100sfi in it...and i want to swap it over to the 3800 series II supercharged motor.. How much money should i need to buy the engine, transmission, and computer? A friend of mine and I are going to do the installing so there shouldnt be much labor.....does 3000 sound like enough? and is it possible to have the 3800 supercharged w/ a standard transmission? or does that take a lot of custom work to have done? Quote
Reapper Posted May 6, 2003 Report Posted May 6, 2003 It really depends on where you get the parts from. I have been told anywhere from $1000 to $3000 just for the parts. The last engine/trans & wires I saw on e-bay went for $2000. SO 3 grand could give you just the parts or parts and extra money for Misc. things. If you can find a donar car before you get your loan then you should be able to know around how much you'll want to ask for. Laterz, William Grimmer Quote
Robby1870 Posted May 6, 2003 Report Posted May 6, 2003 I have heard 1500-2500 for engine and tranny. Check out http://www.j-body.org some guys there know how to mate a Getrag 282 to the L67 Robby Quote
Slade901 Posted May 6, 2003 Report Posted May 6, 2003 3000 Grand? Wow, I guess you would be spending that kind of money upgrading your engine, transmission, computer and perhaps other misc items. Personally, I would use money that for my planned fiero based kit car Quote
Guest TurboSedan Posted May 6, 2003 Report Posted May 6, 2003 yeah i think you can pull it off with 3 grand easy. you can put a Getrag 282 on there with a custom flywheel too. too bad it's so much more of a PITA to put a 5-speed in a '94+ W-body tho (clutch pedal mounting). i say go for it! joshua Quote
lukee1982 Posted May 7, 2003 Report Posted May 7, 2003 Check out http://car-part.com search by your area and see what a motor and trans range in your area it will give you an idea before you call the place Quote
