rockfangd Posted July 18, 2006 Report Posted July 18, 2006 i have an electrical problem. 1994 olds cutlass supreme s 4 door sedan. my ac compressor works but the 2 prong connector has ground but the positive side never has power ever, the only time it kicks on is when i run a wire to the positive side wire direct. anyone know where the wire comes from that goes to the positive side of the compressor the pos is green. all relays and fuses have been checked numerous times and also my feul is just the opposite, i can disconnect my f/p relay and fuse and the car will just keep running i have driven it for over a week without the fuses and relays for the f/p. are these common probs probably not because it is my car lol. thanks :willynilly: my car is possessed. oh yeah not digital climate control. dont know if it is possible to convert. i dont like the manual one but i tried the digital one and it had all electrical connectors and mine has half elec and half vac. thanks Quote
DiscoStudd Posted July 18, 2006 Report Posted July 18, 2006 The PCM sends a signal to activate the AC compressor, only if the pressure in the system is at an acceptable level. This is so you don't do any damage to the compressor if the refrigerant level is low. Check to make sure you have sufficient refrigerant in the system before proceeding... Quote
rockfangd Posted July 18, 2006 Author Report Posted July 18, 2006 thats good that it poses as a safety. i didntknow that. i think it actually be a clogged accumulator because the system is fully recharged but does not work Quote
rockfangd Posted July 20, 2006 Author Report Posted July 20, 2006 anything else you know. lol thanks Quote
Crazy K Posted July 20, 2006 Report Posted July 20, 2006 the relay is on the passenger side front. check if it is alright and not corroded.... perhaps try a new relay. WHen i service the AC system, I use a relay which I removed the cap from, and manually trigger it with a toothpick. Quote
rockfangd Posted July 21, 2006 Author Report Posted July 21, 2006 interesting. i will have to try that. i know the relays are all brand new. because i have been trying to repair the other electrical mishaps lol. thanks Quote
