97loudcut Posted July 17, 2006 Report Posted July 17, 2006 Thinking about buying the FFP motor mounts and I was just wondering what was everyones expierence with them. What are the good and the bads and are they worth the money. Did you notice any diffrence? Quote
SigEpCutlass Posted July 17, 2006 Report Posted July 17, 2006 IIRC, you will have to change your metal brackets to use those mounts...you will need the Pre '94 brackets. Quote
Psych0matt Posted July 17, 2006 Report Posted July 17, 2006 i bought mine used for like 40$. I didn't notice an incredible difference, but at the same time everything seemed to be tighter and less sloppy. I think it's worth the money just knowing it wont wear out, but that's just me Quote
97loudcut Posted July 17, 2006 Author Report Posted July 17, 2006 IIRC, you will have to change your metal brackets to use those mounts...you will need the Pre '94 brackets. huh? why? Quote
SigEpCutlass Posted July 17, 2006 Report Posted July 17, 2006 I was told in the past that the brackets were different. I have an early '94 car, so I still have the older style of mounting brackets. Quote
digitaloutsider Posted July 17, 2006 Report Posted July 17, 2006 If you have the newer generation mounting brackets they won't work. They don't fit. Quote
z284pwr Posted July 17, 2006 Report Posted July 17, 2006 I have them, they have done a fine job on our TGP....and they look a HELL of a lot better than the stock wimpy looking things Quote
19Cutlass94 Posted July 18, 2006 Report Posted July 18, 2006 Q: Will the 3.1 W-body dog bones fit my 3100 W-body?A: Yes and No. Some late model '93s and early model '94s with the 3100 SFI use the same mounts as the 3.1 MPFI. The easiest way to tell the difference is to look at the end of the dog bone above the radiator. If that end has a large square rubber bushing, then it has the newer 3100 SFI style mounts. If both ends of the dogbone have a round rubber bushing, then it's most likely a 3.1 MPFI style mount. If you have the 3100 SFI style mount and want to use the 3.1 MPFI style, you can use all the brackets and hardware from a 3.1 MPFI. You can usually find the necessary brackets and hardware at a salvage yard fairly cheap. Quote
Z34-5speed Posted July 18, 2006 Report Posted July 18, 2006 I have the dogbone for the LQ1 and i love it. It makes the inside of the car alot louder and you feel the engine moving. Great quality. Kyle Quote
19Cutlass94 Posted July 18, 2006 Report Posted July 18, 2006 and be prepared for all the new found rattles youll get! I spent 3 years trying to get rid of all of mine. I think Im almost there Quote
Euro Posted July 18, 2006 Report Posted July 18, 2006 meh i had mine on the car for like 2 weeks. got sick of the shaking of the car/rattling etc and took them off. IMO they're too expensive, but thats just me Quote
blkinternational Posted July 18, 2006 Report Posted July 18, 2006 still got those FFP dog bones u said you took off cause of ratteling..if so..il buy those off you. Quote
Robby1870 Posted July 18, 2006 Report Posted July 18, 2006 I just drilled out the engine side of the factory dog bones to a 1 3/4" hole. Got some Fiero torsion brace ( I think) poly-U bushings and installed them. Usually, the radiator side of the dogbone bushings arent too bad. So, each of my dogbones is 1/2 poly-U. You get the best of both worlds this way. No slop when shiftings from R to D or normal shifting, etc, but none of the engine vibrations are felt in the car. I had done this to both ends of my dogbones for a while and couldnt stand the vibration. This solved the problem. Quote
Euro Posted July 19, 2006 Report Posted July 19, 2006 still got those FFP dog bones u said you took off cause of ratteling..if so..il buy those off you. na..i sold em last summer to EurosportZ34 on here Quote
97loudcut Posted July 24, 2006 Author Report Posted July 24, 2006 well since i ownt be getting those.. can I run the UD pulley with a 1600 watt amp? (I do have an Optima Yellow Top) Quote
slick Posted July 24, 2006 Report Posted July 24, 2006 well since i ownt be getting those.. can I run the UD pulley with a 1600 watt amp? (I do have an Optima Yellow Top) If I were you, I would consider upgrading your alternator and redo your power and ground cables to 4 guage. BTW, if you really want to get the dogbones, maybe me, tony, and you could hit up parts galore and pull the correct mounts for ya. Quote
97loudcut Posted July 24, 2006 Author Report Posted July 24, 2006 well since i ownt be getting those.. can I run the UD pulley with a 1600 watt amp? (I do have an Optima Yellow Top) If I were you, I would consider upgrading your alternator and redo your power and ground cables to 4 guage. BTW, if you really want to get the dogbones, maybe me, tony, and you could hit up parts galore and pull the correct mounts for ya. okay Quote
