rockfangd Posted July 16, 2006 Report Share Posted July 16, 2006 hi i have a 1994 olds cutlass supreme sl with the base cluster with tach. i was at a salvage yard and i found a digital dash cluster out of a 1990 olds cutlass supreme. heres the problem the plugs appear to be the same except there are 2 peices on the outside of the plug that have to line up with the connector on the cluster. mounting wise it is fine. i need to know if i shave off the 2 peices so it will plug in will it work or do i have to change the wiring. if thepeices are shaved off the plug lines up perfect but i do not want to short out anything. also does anyone know the schematics for the wires for both the standard base cluster and the digital one. so i know if i have to relocate wires. thanks rockfangd@aol.com Link to comment Share on other sites More sharing options...
jeremy Posted July 16, 2006 Report Share Posted July 16, 2006 use the search feature to search for UB3 swap...this has covered 1923487395871054x http://www.w-body.com/forum/index.php?action=search;advanced Link to comment Share on other sites More sharing options...
Crazy K Posted July 16, 2006 Report Share Posted July 16, 2006 re-wiring will also be necesary. you can repin if you can get the pinouts. Link to comment Share on other sites More sharing options...
rockfangd Posted July 16, 2006 Author Report Share Posted July 16, 2006 can you tell me how to get the pinouts. i already know how to remove the wires with a tiny screwdriver Link to comment Share on other sites More sharing options...
jeremy Posted July 16, 2006 Report Share Posted July 16, 2006 can you tell me how to get the pinouts. use the search feature Link to comment Share on other sites More sharing options...
