Any Ideas?
I just got some spare tail lights from Redfox (thanx agian). I am wanting to turn them in to clears. Anybody have any ideas? If not I'll try and figure it out on my own. I'll be making a page if I can get it to work. Wish me luck.
Laterz,
William Grimmer
Thanks I'm going to try and start working on them this week if I can find the time. I figured this had already been discussed but wasn't sure.
Laterz,
William Grimmer
you have a 95 Cutlass right? there is a guy on soundomain.com with clears on his 89 cuttlass, I'm sure they'd be similar, Here's his site.....................http://www.sounddomain.com/member_pages/view_page.pl?page_id=217528&page=4 Hope that helps Reapper, good luck making them...
Thanx a lot Bake ya the lights are the same from what I can see. I was going to get started today but no time. You know they actually wanted me to work at work today. Go figure. So till tomorrow.
Laterz,
William Grimmer
My car's both tail light has been deeply scratched up all over and so I might try that clear tail light on my 1990 Cutlass Supreme.
Short Update: I've gotten some of it cut apart. actually only about 3 edges out of 8. Kinda slow going. Trying to find the best way to take the lense apart at the seams. Not easy with the damn curves. The best way I have found to cut the semi stright sides is to cut thru in one area a large enough hole so a hack saw blade can fit in. Then just run down the seam with the hack saw blade. If anyone has any ideas of how I can get the top and bottom sides cut at the seam it would help a lot. Also the heat gun idea to release the glue isn't working just making the plastic really soft, and in a couple places tryed to burn it. Thats about the only heating tool I have which sucks. I think if I had a hot wire or a soidering iron with blade it would work better. So any more ideas would be great. Thanx for the help so far.
Laterz,
William Grimmer
on similiar projects, i have had success in the past using a dremel rotary tool... let us see the pics when done. have fun !
If all goes well I'm going to make a "How I did it page". Lets just hope all goes well.
Laterz,
William Grimer
