briandors Posted July 14, 2006 Report Posted July 14, 2006 Fuel pressure is 0 to 5 psi. Car will idle, barely, can't accelerate. Can I be sure it's the fuel pump? Could it be the fuel pressure regulator? How would diagnose the difference. Fuel filter replaced during troubleshooting process and that didn't help. Thanks Brian 1989 Regal 3.1 Quote
briandors Posted July 14, 2006 Author Report Posted July 14, 2006 No, I don't think so, but not 100% sure. Any other tests? Quote
Turbo231 Posted July 14, 2006 Report Posted July 14, 2006 It's the fuel pump. You didn't mention mileage, but your car is old enough. I think even if the FPR totally crapped out, you'd still have some pressure. Need some help...check out my procedure on doing your pump. http://members.aol.com/regal231/fuel.htm You'll want to change your filter again a little bit after changing your pump. Banging around all those lines and shaking up the tank kicks a lot of crap into the system. Quote
