chadz34 Posted July 13, 2006 Report Posted July 13, 2006 My ''LOW OIL'' light came on randomly! First thing I thought was where the fuck did it go? I am using syntehic oil, so I am guessing ti is seeping past engine parts and making my exhuast smell weird, I am gonna covert back to 10W-30. Quote
1990lumina Posted July 13, 2006 Report Posted July 13, 2006 So it was in fact low, just not a false sensor reading?? That sucks dude. Quote
SigEpCutlass Posted July 13, 2006 Report Posted July 13, 2006 hold on just a second now Chad. 1. What synthetic oil are you using? (Don't worry, I'll try my hardest to avoid pitching Amsoil ) 2. Do you see any visible leaks on the block of the engine on the front or rear? 3. What does the dipstick reading show? 4. Put paper under your car to see if you isolate any hard to see or non-visible oil leaks. A leak is a leak and it still might exist even if you switch to a higher weight oil. Let us know what you find. Quote
19Cutlass94 Posted July 13, 2006 Report Posted July 13, 2006 Ive had that happen before. Except mine was with leaking gaskets and a leaking oil pump drive seal o-ring. Yeah I had to drive like 10 miles to the nearest place to get oil More than likely you have a leak somewhere. Its probably best to find it and fix it. because I know when my car was leaking, I was putting in a quart every week. Quote
chadz34 Posted July 17, 2006 Author Report Posted July 17, 2006 hold on just a second now Chad. 1. What synthetic oil are you using? (Don't worry, I'll try my hardest to avoid pitching Amsoil ) 2. Do you see any visible leaks on the block of the engine on the front or rear? 3. What does the dipstick reading show? 4. Put paper under your car to see if you isolate any hard to see or non-visible oil leaks. A leak is a leak and it still might exist even if you switch to a higher weight oil. Let us know what you find. I am using Castrol Syntec. I am gonna use Quaker State Peak Performance tomorrow, it's on sale. The dipstick is still in the safe zone because it is on the line before it needs to be added. Quote
chadz34 Posted July 17, 2006 Author Report Posted July 17, 2006 No leaks on the ground ANYWHERE. Quote
Crazy K Posted July 17, 2006 Report Posted July 17, 2006 umm quaker state sucks... their oil has too much wax in it and causes sludge yeah the car warns you of low oil, but I would estimate that it is only halfway to the minimum amount from full that you can get. and yeah I have abused the low oil light before too. some cars did have issues with false low oil signals, btw, due to decompostion of the float. Quote
chadz34 Posted July 17, 2006 Author Report Posted July 17, 2006 umm quaker state sucks... their oil has too much wax in it and causes sludge yeah the car warns you of low oil, but I would estimate that it is only halfway to the minimum amount from full that you can get. and yeah I have abused the low oil light before too. some cars did have issues with false low oil signals, btw, due to decompostion of the float. What oil doesn't fucking suck? I'm gonna hear 3498579 different kinds.... Quote
digitaloutsider Posted July 17, 2006 Report Posted July 17, 2006 I've run Supertech synthetic religiously for the past 2 years, though the Cutlass has Royal Purple in it right now. Quote
RJansen658 Posted July 17, 2006 Report Posted July 17, 2006 Ok here is some info, this first one is kinda dumb, since it comes from amsoil, of ourse it shows thier oil is the best: http://www.amsoil.com/performancetests/g1971/ And this is a free ebook called the motor oil bible. It tells you what tests there are, and basically anything else you would want to know about oil, it covers synthetics too: http://www.trustmymechanic.com/motor-oil-bible.pdf Quote
GP1138 Posted July 17, 2006 Report Posted July 17, 2006 There are a few people on here (pitzel, I'm looking at you) who are absolute oil info gods. I expect one of them any minute. Quote
SigEpCutlass Posted July 17, 2006 Report Posted July 17, 2006 http://www.bobistheoilguy.com/ Jay quoted a very good website. I'd go there so you can understand what (if anything) Pitzel says if he sees this post. Ok here is some info, this first one is kinda dumb, since it comes from amsoil, of ourse it shows thier oil is the best: http://www.amsoil.com/performancetests/g1971/ And this is a free ebook called the motor oil bible. It tells you what tests there are, and basically anything else you would want to know about oil, it covers synthetics too: http://www.trustmymechanic.com/motor-oil-bible.pdf I also agree that Amsoil is the best oil that money can buy. I use Amsoil Series 2000 Synthetic 0W-30 in my car, and my dad uses it in all my family's cars. I'll refrain from saying anything further so I don't sound like an Amsoil rep again. Quote
chadz34 Posted July 17, 2006 Author Report Posted July 17, 2006 I put Quaker State PeakPerformance 10W30 in the Lumina about 30 minutes ago....gave it a qucik start-up and for one thing, it's quieter. Quote
