Noise through speakers with Heat or AC turned ON?
Whenever I turn on my AC or Heater in my 89 Cutlass Supreme I get what is almost the same as alternator whine through my speakers. I don't know if it's the alternator or the blower motor? What should I check? Grounds?
THANKS!:)
I've had factory amps go bad and this would be a symptom. I'm including the "internal" amp aka the upper part of the factory radio. But first definetly check over grounds and check the connections at the blower motor, climate control, and radio.
Yeah right now there's not even a radio or any radio exquipment in the car...
Do you have the bass gain switch on the dash? If so, you have an extra amp under the dash. Just an FYI
