rudefyet Posted July 10, 2006 Report Posted July 10, 2006 I'm wondering what would cause this, and what to look for Whenever the engine is running my radio reception sucks donkey dick...like something is interferring w/ the antenna When the engine is off, the radio is perfectly clear, but with it on theres a ton of static that seems to match the engine rpms any advice would be appreciated Quote
19Cutlass94 Posted July 10, 2006 Report Posted July 10, 2006 Ground loop/bad ground? Is it almost like a ticking kind of noise that goes with the RPM? Quote
rudefyet Posted July 10, 2006 Author Report Posted July 10, 2006 it's more like a popping noise what ground would be bad though...the stereo, chassis, or what? Quote
slick Posted July 10, 2006 Report Posted July 10, 2006 You don't have power antenna do you? Not that it should really matter though. BTW, where is your antenna located at on your truck? And, IIRC, you have an amp in your truck, right? Quote
rudefyet Posted July 10, 2006 Author Report Posted July 10, 2006 antenna is on the front passanger side...no power antenna and yes I have an amp...and the power cable does run right by the antenna Quote
1990lumina Posted July 10, 2006 Report Posted July 10, 2006 Make sure the antenna isn't grounding out to the vehicle chassis (make sure the the rubber seal along the body metal it still intact) Quote
rudefyet Posted July 11, 2006 Author Report Posted July 11, 2006 didn't do that yet...that might just be it cause I just ran a new ground to the cd player to no avail. I even unplugged my amp from the battery, still didn't help And now I noticed it disappears if I unplug the antenna from the back of the stereo or in the engine bay Quote
slick Posted July 11, 2006 Report Posted July 11, 2006 Sounds like you may have a break in the antenna line. Quote
rudefyet Posted July 30, 2006 Author Report Posted July 30, 2006 bump...any other ideas I'm gonna tear into this tomorrow...it's driving me nuts Quote
19Cutlass94 Posted July 30, 2006 Report Posted July 30, 2006 On the back of the radio, check the antenna line going in. For some reason mine keeps coming undone and its horrible. But Id check that antenna line, or check the antenna ground. Quote
Mach 5 Posted August 7, 2006 Report Posted August 7, 2006 Check your antenna. If it ain't that then, I think its your spark plug wires. The reason car manufacturers don't use copper spark plug wires anymore is do to this. People don't want radio interferrence when the car is running. When you upgrade your system, it can be more sensitive to this pulsation from the wires even with newer technology. I would do an upgrade to the wires. They could be old and the insulation might not reduce the electrical static that creates this noise. Todays wires you can't usually get a reading of condinuity on a multimeter. The only reason electrical pulses get through the wires is do to the high voltage. Quote
94CutlassXtreme Posted August 23, 2006 Report Posted August 23, 2006 It's just ground noise, check the ground wire in the headunit harness and the ground wire for the amp, chances are one of them is touching bare metal. Other than that, you could try putting little rubber o-rings between the amp and whatever its bolted to. Quote
rudefyet Posted September 11, 2006 Author Report Posted September 11, 2006 Looks like Mach 5 was right, after tuning up my ignition system today (new plug wires, cap and rotor) there's no more static. In fact I can now pick up stations that I couldn't pick up before. Woohoo! Quote
