bigshynepo Posted July 9, 2006 Report Posted July 9, 2006 If I have been driving around in hot (28 degree celcius, 90 degree F) sunny days for a week with 2 L / 2 quarts of coolant low..... would I have caused any additional wear and tear on my system in anyway? (3.4L DOHC) I asked my mechanic to make sure everything was all good with my coolant after my gasket and timing belt change, he assured me it was no problem and all topped up. Turns out I was almost bone dry in my reservior when I finally looked at it after it sitting all night (no leaks either). I go back tomorrow to demand answers!! I really appriciate any help you all could be. Thanks in advance. (I know that the cooling system on these cars/engines are a little tricky) Quote
THe_DeTAiL3R Posted July 10, 2006 Report Posted July 10, 2006 Did the engine run hot? If it ran normal temp I don't think it would have hurt anything. Maybe there was air in the system that wasn't bled properly... it can really suck up the coolant. Is it still losing coolant after you added the 2qts? Quote
bigshynepo Posted July 10, 2006 Author Report Posted July 10, 2006 No, after I filled it up, it hasn't gone down. The air was clearly not bled properly from the system when they were adding. I am going to request they do a coolant flush and refill (I had to pour water in). It did run hotter than average. I checked the level because I noticed the second fan was always running. Even when it was running, it seemed to be fighting a losing battle against the heat. I don't think I was driving my car for long enough periods to have it overheat but I feel it would have if I kept driving. Quote
THe_DeTAiL3R Posted July 10, 2006 Report Posted July 10, 2006 Did you have the A/C on? I thought the second fan comes on automatically... Quote
bigshynepo Posted July 10, 2006 Author Report Posted July 10, 2006 No, didn't have the A/C on, it seems like the car got hot very fast off the start. My second fan would kick in within 15-20 min of light driving. By then, my needle was well past halfway on the temp gauge (the new 95 style gauge) Quote
1990lumina Posted July 10, 2006 Report Posted July 10, 2006 If you didn't get past 3/4 on the guage I wouldn't worry about it....my Lumina will go as high as a bit past half, fan(s) kick on and BOOM temp is back down right away... Quote
Regal_GS_1989 Posted July 10, 2006 Report Posted July 10, 2006 I would take it back in where the work was done, and Bitch about that. It is possible that there was damage done, but if there are no air bubbles in the reservoire, and it doesnt run hot after you top it up and bleed it, than you should be fine. Quote
