i have a 91 grand prix and i do not have any low beams, the high works fine and so does the dash blue indicator, but flick the turn signal and it turns off the high and does not light the low.
i have been told by the dealer that its a headlamp relay but i cannot fine it any where on the fuse/relay panels.
it has a panel in the glove box
a panel under the passenger foot well
and a panel on the interior passenger side of the engine compartment
any idea where this relay is???
Guest Anonymous
In the engine compartment, passenger side, UNDER the fuse panel. Pull the access panel off that goes down beside the engine. Your computer is under there and there should be a relay center for the headlights.
thanks for the help, but i replaced the relays in the block and the low beams still do not work, looking into this a bit more the daytime run lights do not work either, so i have another question, can you tell me where the daytime run light cotroller is?
thanks
