GuruUno Posted May 2, 2003 Report Share Posted May 2, 2003 Installed trip computer/DIC for 94 GP, works fine, except temp reads -40 degrees, duh, no sensor. Purchased one from dealer, verified mounting location on front of radiator support where holes are provisioned, but no harness plug to plug into it! I removed acess covers and peeled back the wiring loom plastic covers from end to end, and could not find one taped up, cut back, hidden, etc. THe DIC and HUD wiring was all in place when I installed those items (behind dash), taped up as written about here, but now kinda stumped for the temp sensor plug, anybody have this knowledge to share, or know what wires and where they may be? Quote Link to comment Share on other sites More sharing options...
cutlassdude96 Posted May 4, 2003 Report Share Posted May 4, 2003 Is this for the outside temp., if so try looking around in the head light harness. Quote Link to comment Share on other sites More sharing options...
GuruUno Posted May 4, 2003 Author Report Share Posted May 4, 2003 And I even went to the dealer, they could not find. Pics anyone? Quote Link to comment Share on other sites More sharing options...
backinblack Posted June 8, 2005 Report Share Posted June 8, 2005 The wiring connector should be between the headlights in the large loom. If not, you will have to run your own wiring back to the trip computer, splicing into the 2 temp sensor wires that are already there. I believe they terminate in the firewall connector on the passenger side. Quote Link to comment Share on other sites More sharing options...
GP1138 Posted June 8, 2005 Report Share Posted June 8, 2005 I asked this question last week and got much the same response. I ended up wiring it into the harness behind the dash myself. I didn't run enough wire, and my outside air sensor is now an interior air sensor, often reading over 100 degrees! Run an assload of wire and you should be good. Quote Link to comment Share on other sites More sharing options...
