Q-Ball Posted July 5, 2006 Report Posted July 5, 2006 I bought this thing from Canadian Tire a while ago while it was on sale. Never tried installing it. Just wondering how hard/easy it would be. Thanks http://www.canadiantire.ca/assortments/product_detail.jsp?PRODUCT%3C%3Eprd_id=845524442890773&FOLDER%3C%3EbrowsePath=2534374303517494&FOLDER%3C%3EbrowsePath=2534374303517533&FOLDER%3C%3EbrowsePath=1408474396669482&FOLDER%3C%3Efolder_id=1408474396669482&ASSORTMENT%3C%3East_id=1408474396670271&bmUID=1152079617268 Quote
89GP_SE Posted July 5, 2006 Report Posted July 5, 2006 its pretty straight forard, it will take you the better part of a saturday and a 12 case of canadian to get done. my advice to you is READ the INSTRUCTIONS CAREFULLY!!! and be PATIENT with it. Quote
CSI_MuNkY Posted July 5, 2006 Report Posted July 5, 2006 Its electrical, once you give the instructions a read through, it should be a peice of cake for you. Jamie Quote
Q-Ball Posted July 5, 2006 Author Report Posted July 5, 2006 its pretty straight forard, it will take you the better part of a saturday and a 12 case of canadian to get done. my advice to you is READ the INSTRUCTIONS CAREFULLY!!! and be PATIENT with it. Oh good. I might give her a try today than! Thanks! Its electrical, once you give the instructions a read through, it should be a peice of cake for you. Jamie Bah why didnt I read the instructions yet? Maybe you could be my sidekick for this adventure. Want me to get you a wiring diagram? Oh yes please! And how do you get all these sort of goodies? Cause I want some! Great help, Thanks Quote
slick Posted July 5, 2006 Report Posted July 5, 2006 12volts red + ignition harness Starter yellow + ignition harness Ignition pink + ignition harness Second Ignition dark blue/white + ignition harness Accessory orange + ignition harness Second Accessory purple/white + ignition harness Power Lock lt. blue + either kick Power Unlock black + either kick Parking Lights+ brown headlight switch Notes: Also found low in the drivers kick panel. Parking Lights - Door Trigger white - headlight switch Notes: Also found low in the drivers kick panel. Dome Supervision use door trigger Trunk/Hatch Release black + release switch Tachometer pur/wht or white ac igniton coil Notes: Also found at the instrument cluster as white. Brake Wire white or lt. blue + brake switch Horn Trigger black - steering column BTW, for trunk pop, you will need a relay. Hope this helps. Quote
slick Posted July 5, 2006 Report Posted July 5, 2006 Get it in yet? It shouldn't take you too long to do. Quote
Justin Posted July 6, 2006 Report Posted July 6, 2006 http://bulldogsecurity.com/ is a great place to get free wiring diagrams, but most of their stuff is garbage. Good luck with the install, if you have any problems with a specific ckt some of us have installed them before and we should be able to get you through it. Quote
1990lumina Posted July 6, 2006 Report Posted July 6, 2006 The trunk popper on my UNGO system is just spliced into the wiring from the trunk popper button under the dash :? (I know this because when I installed my fog light switch (right beside the trunk popper) I saw how the installer just spliced it on lol....I hate when they do that but whatever it works fine... Quote
Psych0matt Posted July 6, 2006 Report Posted July 6, 2006 http://bulldogsecurity.com/ is a great place to get free wiring diagrams, but most of their stuff is garbage. Good luck with the install, if you have any problems with a specific ckt some of us have installed them before and we should be able to get you through it. I have a bulldog system (from previous owner) and I haven't had any problems with it other than the remote breaks easily. I actually like the way it does things, but I also can't say ive had any experience with other aftermarket setups Quote
Q-Ball Posted July 29, 2006 Author Report Posted July 29, 2006 I looked it over. It looks a lot more complicated than I thought. I'll have to pay someone to install it I guess... haha Quote
