Coolant leak
Found a Minor coolant leak from the driver's side. leak is most visible on the transmission near the TV cable. Any ideas?
Possible Intake maifold gasket, thermostat bypass tube, or head gasket. Use a coolant pressure checker to test for leaks....
nvm, I think it's coming from the TB hose. now I just need to figure out if I want to block it oof or replace the hoses.
Ok.. apparently that wasn't it. the hoses were in bad shape, but it's still leaking from what looks like the back of the engine
