HELP!!! Mounting front bumper cover???
those bolts are some goofy size, if you can, pop the bracket with those studs on it off the fender and take it to a hardware store and get them to find you the bolts.
have you ever seen the nust that go there or are you in the dark about it? there 10mm nust but there wierd. i cant really explain it but there not normal. if at all possible go to a junkyard and get some, BTW, you will need a deep socket to get them off and on. the studs are welded in place so they dont come off.
http://www.crestnetsales.com/restore/pushnuts.htm
they have them here just for refrence. (the first kind) hard to tell in the pic but they seem like there were made from sheet metal and pressed into nut form.
so nvm i found the nuts i needed. my dad moved them and gave me them when he got home. Thanks for the support tho! :biggrin:
