mischief3003 Posted June 28, 2006 Report Posted June 28, 2006 I have the 3100 in my gp. I was wondering it its a good engine or not. Like wahts the most common problem with it? How many miles do they last before any major problems? Whats the average MPG? how dumb of a question taht might be. Also the tranny( 4spd auto) how long do they usually last? Quote
Robby1870 Posted June 28, 2006 Report Posted June 28, 2006 Treat it like any 12 year old car. Do regular maintainence, plugs, wires, sensors, filters, fluid changes, etc and it'll last a long time. Average mpg for a 3100 in a W is around 20 city, 30 highway, if it's properly maintained. Quote
mischief3003 Posted June 28, 2006 Author Report Posted June 28, 2006 When should the gaskets be changed? Quote
cutlsp Posted June 28, 2006 Report Posted June 28, 2006 if you have no record of them ever being changed either have them changed or do it yourself if your mechanically inclined. Quote
19Cutlass94 Posted June 28, 2006 Report Posted June 28, 2006 With proper care, a 3100 will last a LONG time. The biggest problem with these engines is the upper and lower intake gaskets. If you oil becomes milky, change them asap. If you start loosing coolant and dont know where its going, change them asap. As much as people here complain about the 3100 ( lack of power etc etc ) it really is a good engine, and no one can deny that. Quote
94CutlassSLCoupe Posted June 28, 2006 Report Posted June 28, 2006 Its a really good engine, and for the era, it makes plenty of power, especially for being the base V6. Seeing as how i've run mid 16 1/4 miles with it, being totally stock, it can still hang with a lot of stuff on the road. I guess I just don't expect miracals from a 1994 car. Change the intake gaskets and also change to the aluminum valve covers if you have the plastic ones. Change the spark plugs and drop the transmission pan and change the fluid and filter and you should be all set. Quote
mischief3003 Posted June 28, 2006 Author Report Posted June 28, 2006 Well i got new tranny fluid and a gasket. What spark plugs would you recommend? Quote
mischief3003 Posted June 28, 2006 Author Report Posted June 28, 2006 Ok ive heard about them before. Anything else i should do? My engine has 124,xxx miles on it. Quote
97loudcut Posted June 28, 2006 Report Posted June 28, 2006 when i did my tune up i got ac delco plugs and wires (platinum plugs because that is what is stock), fram fuel filter, pcv vavle, cleaned my k&n, cleaned the engine (clean engine run cooler then dirty ones), and a added some fuel systems cleaner to a empty tank of gas then filled up. When it comes to the gaskets I wouldnt recommend changing them until you see some warning signs. No reason to replace something that is working fine. Quote
jeremy Posted June 28, 2006 Report Posted June 28, 2006 When it comes to the gaskets I wouldnt recommend changing them until you see some warning signs. No reason to replace something that is working fine. I would bet that his intake gaskets are leaking, unless they have been replaced already Quote
MonteCarloChick Posted June 28, 2006 Report Posted June 28, 2006 It's better to replace something now then have to replace something way more expensive down the road. Quote
mischief3003 Posted June 28, 2006 Author Report Posted June 28, 2006 Alright so so far I need to change my intake gasket, change my oil and coolant(been on list for a while), change my plugs and wires, and filter. Missing anyhting? Also what intake gaskets or both? Quote
slick Posted June 28, 2006 Report Posted June 28, 2006 Both upper and lower intake gaskets. It will come as a kit if you plan on doing them yourself. BTW, if you do them yourself, set a weekend aside to do it, you will need the time starting like on a friday evening, until late saturday. If you are good with engine repair, maybe just 1 days worth of work. Having a shop do them, be ready to cash in anywhere between $500-$900. Quote
mischief3003 Posted June 28, 2006 Author Report Posted June 28, 2006 How much to do them yourself. I could bring them up to the auto shop at my school and my teacher would help me do them. Quote
Brian P Posted June 28, 2006 Report Posted June 28, 2006 http://www.w-body.com/forum/index.php/topic,45932.0.html Quote
SigEpCutlass Posted June 28, 2006 Report Posted June 28, 2006 I have the 3100 in my gp. I was wondering it its a good engine or not. Like wahts the most common problem with it? How many miles do they last before any major problems? Whats the average MPG? how dumb of a question taht might be. Also the tranny( 4spd auto) how long do they usually last? Yes. Just watch for the Intake Gaskets. It's a better version of the pre'94 3.1 engine with more hp & torque. Quote
THe_DeTAiL3R Posted June 28, 2006 Report Posted June 28, 2006 Pros: Better fuel econemy, and slightly more HP than the older 3.1 MPFI engines. Clean running, and less problems with carbon and crap that cause the MPFI engines to run shitty sometimes. Cons: Lower intake gasket. I wouldn't nessesarily say change them ASAP, but always keep an eye on your coolant reservior, if it starts drinking coolant then stop driving the car and change the gaskets. You never know if they've been replaced already (and when) so you might be fine for a while... Quote
94cutlatized Posted July 1, 2006 Report Posted July 1, 2006 I F*@ked my tranny pretty quick, (thats me tho) and my engine locked up not too long ago. Other that that, i was surprised how much it took my foot. 15.9 best time, delco wires,rapidfire spark plugs, ported intake, dynomax dual exhaust, some intake work. Ran against a gt grand am he did a 16.3. GOOD ENGINES IF TREATED RIGHT Quote
