Nick1234 Posted June 26, 2006 Report Share Posted June 26, 2006 on my 93 Lumina, the trip odemeter hardly works. It goes up to .9 then eventually will get stuck at maybe 1.9, and won't go any higher than 9.9 but it takes a while to get there. What should i look for. What makes it work? Nick Quote Link to comment Share on other sites More sharing options...
White93z34 Posted June 26, 2006 Report Share Posted June 26, 2006 i'd sorta like to know that myself, mine works but sometimes i have to push reset a few times for it to go again. Quote Link to comment Share on other sites More sharing options...
PCGUY112887 Posted June 26, 2006 Report Share Posted June 26, 2006 When mine did that the miles stoped counting too till I pressed it again, so I say next time just leave it Quote Link to comment Share on other sites More sharing options...
Nick1234 Posted June 26, 2006 Author Report Share Posted June 26, 2006 well i have sat there and cranked on the reset but that didn't do much. Quote Link to comment Share on other sites More sharing options...
Q-Ball Posted June 26, 2006 Report Share Posted June 26, 2006 I bought a new cluster! Just need the digitalness to work right... Quote Link to comment Share on other sites More sharing options...
Crazy K Posted June 26, 2006 Report Share Posted June 26, 2006 I've fixed and seen similiar problems on odometers and speedometers. the problem is usually caused by slack in the numerical roller assembly. my fix? I bust upen a j/y cluster and take the odometer and trip odo, and use the itty bitty washers that buffer between the parts as a shim to tighten the numbers... unless I find that the gearing is damaged in my car's roller, in which case I substitute the entire numerical roller. problem solved. Quote Link to comment Share on other sites More sharing options...
