ToroToro Posted June 23, 2006 Report Posted June 23, 2006 Okay...as some of you might know, I've been running my custom solid upper engine mounts for awhile now. Last week I decided to take them off and drill them for bushings ( the vibration wasn't bad, but they transmitted a lot of engine noise and I'm tired of it )... I dont know when I'll get over to the shop to finish them, but I got the factory ones back on, and now I get a clunk when ever the tranny goes into gear...IE: reverse, drive.... Also sometimes when I pull into driveways. So now I'm trying to figure out what the hell is wrong. I'm either suspecting the lower engine mount, or the trans mount. I also am going to check the sub frame bolts to see if they are the problem. The dog bones seem to be still good. Anyway, what do you guys suspect to most likely be the problem? I'll see what I can do about getting a vid up. Quote
Brian P Posted June 23, 2006 Report Posted June 23, 2006 If your lower mount is original, then yeah, probably went flat. Quote
ToroToro Posted June 23, 2006 Author Report Posted June 23, 2006 As far as I know it is. Car has 107K miles now so I spose that could be the problem. Quote
19Cutlass94 Posted June 24, 2006 Report Posted June 24, 2006 Its the lower mount. I know the exact noise your talking about. When my subframe was replaced, I had them put in a solid rubber mount, noise has been gone ever since. Quote
97loudcut Posted June 24, 2006 Report Posted June 24, 2006 lower mount...my moms old monte SS had the same problem at like 15000 miles Quote
5speedz34 Posted June 25, 2006 Report Posted June 25, 2006 Its the lower mount. I know the exact noise your talking about. When my subframe was replaced, I had them put in a solid rubber mount, noise has been gone ever since. Why would you have them put in a solid lower mount? Quote
1990lumina Posted June 25, 2006 Report Posted June 25, 2006 My car has been clunking since I got it.....very bad into reverse....other gears it's okay....I should really look into this soon Quote
19Cutlass94 Posted June 25, 2006 Report Posted June 25, 2006 Its the lower mount. I know the exact noise your talking about. When my subframe was replaced, I had them put in a solid rubber mount, noise has been gone ever since. Why would you have them put in a solid lower mount? Because its better than the hydraulic one that comes from the factory. Quote
GnatGoSplat Posted June 26, 2006 Report Posted June 26, 2006 Because its better than the hydraulic one that comes from the factory. How do you figure? Quote
SigEpCutlass Posted June 26, 2006 Report Posted June 26, 2006 Because its better than the hydraulic one that comes from the factory. How do you figure? x2 Quote
Brian P Posted June 26, 2006 Report Posted June 26, 2006 I know the solid aftermarket mounts hold up better than some of the hydraulic aftermarket mounts. I bought an Anchor brand hydraulic mount that went flat (leaked all the fluid) and one mounting stud pulled out in two weeks! And my friend for some odd reason bought the same one later on, and his went bad within a month. Though, right now I'm using a Napa hydro mount, so far so good after over half a year. Quote
GnatGoSplat Posted June 26, 2006 Report Posted June 26, 2006 I guess I got lucky with mine. I put in a hydraulic mount back in the late 90's sometime... 96, 97, 98? Definitely before '99. I think it actually was a cheap Anchor brand. It was so cheap they even painted over the rubber. I remember it was made in India. So far, so good. The ol' 2.8 probably doesn't have enough torque to kill one. The OEM mount would probably still be good today if it weren't for power steering fluid having leaked all over it. That kills them pretty quick. Quote
Brian P Posted June 26, 2006 Report Posted June 26, 2006 I put the Anchor mount on my '90 Cutlass 3.1. The stud that keeps the mount on the bracket is what broke off, and I specifically remember using a torque wrench to get everything tightened to spec. I don't remember it being painted, but Anchor could have changed who makes it within that time period, I put it in around 2002. Quote
19Cutlass94 Posted June 26, 2006 Report Posted June 26, 2006 Right now I just have the solid rubber replacement from NAPA. I put that in beacuse like mentioned above, I dont have to worry about fluid leaking. Although it may not absorb some of the vibrations from the engine like the hydro mount does, its been holding up great since it was put in and it still looks like new. Not to mention it was cheaper. Quote
